Fuel Pump Issues2?
Old Apr 18, 2011 | 06:20 PM
fenix1's Avatar
fenix1
Fuel Pump Issues2?
Pulled codes awhile ago...got a 96. Says "Fuel Pump Circuit Open"-Battery to ECA (1988 On). What is an ECA maybe the Pump Relay? And does this thing have a fuse for the fuel pump in the panel and if so does anybody know which one it is? I' stumped. Fuel Pumps not getting any juice. Anybody got any ideas? HELP!!!
Old Apr 20, 2011 | 07:45 AM
subford's Avatar
subford
96 is most of the time a bad fuel pump relay (or the wiring under the relay).
No fuse in the panel but does have a fuse link coming off the starter solenoid battery side that can can cause this also.
ECA = Electronic Control Assembly
ECM = Electronic Control Module
EEC = Electronic Engine Control module
PCM = Powertrain Control Module.
All the same thing, different names.
And by the book:
Service Code 96 indicates a fuel pump secondary circuit failure between the BATT(+) supply and the FPM connection to the Power-To-Pump circuit.
Possible causes:
No Start:
-- Open circuit between the BATT(+) supply and the FPM connection to the Power-to-Pump circuit.
-- Fuel pump relay contacts always open.
Engine Starts:
-- HEGO short to power (dual HEGO applications).
-- Damaged processor.
adamp29
15
Nov 29, 2016 06:17 PM
kevinwheatcroft
13
Aug 13, 2016 07:26 AM
bjmayberry2
Feb 2, 2016 04:18 PM
75Three90
Nov 7, 2015 03:41 AM
bvmray
May 14, 2000 10:51 PM
