Catch Can
Old Jun 27, 2021 | 07:51 AM
chesster51's Avatar
chesster51
Originally Posted by Mudsport96
Not needed. The filter to oil fill neck is the fresh air INLET to the engine. It is there to let air IN to replace what the pcv is pulling OUT. If you have oil filling that tube and the air inlet tube to the throttle body, you have a problem. The pcv may be bad or there is too much blowby for the pcv to handle. Either way, that line should be clear.
Now I'm leaning towards the driver side being an inlet as you say. In my situation though I believe the vacuum in the hose going to the K&N tube to be greater than what is in the crankcase and would actually be pulling air. Which leads me to thinking about capping the inlet to the K&N tube and installing a simple push in breather on the driver side VC to allow fresh air to enter for the pcv. But, this will be unmetered air that will be entering the upper intake. As it is, that may be the case with the K&N tube anyway since the inlet on the tube is after the MAF. Tis confusion!
Old Jun 27, 2021 | 03:38 PM
chesster51's Avatar
chesster51
Thoughts on the unmetered air?
Old Jun 27, 2021 | 07:46 PM
R&RFord's Avatar
R&RFord
It will function the same either way. Air should only move into the crankcase when the PCV valve is open, with the evacuated air being drawn into the manifold which is accounted for in the computers calibration.
In theory it is a can with two ports, the PCV valve and the breather. Vacuum on either end without a vent on the other end won't move much if any air. The air, fumes, and oil in the crankcase are irrelevant to the fuel air ratio until they are drawn into the combustion chamber via the intake manifold.
The vacuum that exists in the air inlet tubes is pulling against a brick wall unless there is a leak in the crankcase. When the PCV valve opens it will have a stronger vacuum signal than that in the tube and the air would be drawn into the intake.
Reality is that most of these engines probably have some crankcase leakage, so sure you may see some air, fumes, and oil being drawn into the air filter box or air inlet tubes.
Old Jun 27, 2021 | 09:02 PM
chesster51's Avatar
chesster51
Thanks for sharing your knowledge, you've talked me into just leaving the driver side as is. I still think the catch can will be beneficial on the pcv side.
Old Jun 27, 2021 | 09:29 PM
R&RFord's Avatar
R&RFord
It is benefit in catching oil. It is a detriment in that it is a further use of and potential leak for manifold vacuum.
The ideal would be a screen that keeps oil out of the PCV valve in the first place.
But, until someone brings that to market we will make do with what we have.
Old Jun 29, 2021 | 02:17 AM
TexasGuy001's Avatar
TexasGuy001
Originally Posted by SFaulken
Yes, they used to vent that line to atmosphere, they were called road draft tubes. And I consider them irresponsible nonsense, unless you've got something that is some sort of concours level collectible. Don't dump your junk on the ground.
I remember really old early 60s cars having draft tubes, but many things in the 60s up into maybe the the early 70s had open breather caps.
Some carbed vehicles did have the breather tube connected to the air cleaner.
I have seen countless trucks like ours suck oil up through that into the intake or air tube, even back when they were only a few years old with under 100k on them.
I'm not saying that the old previous way of venting to the atmosphere is the best way, I am just questioning how is it that design is not going to act like a second non valved PCV connection? It seems that the breather being open to outside air would allow the PCV to actually evacuate crank case fumes more efficiently since fresh air could be drawn in without fighting the air intake suction.
Old Jun 29, 2021 | 02:21 AM
TexasGuy001
Some vintage car friends of mine like this ME Wagner PCV valve and say it works quite well for oil being sucked up the PCV hose.This is usually on non stock mildly built hot rodded engine setups.
Dual Flow Adjustable PCV Valve ? M/E Wagner Performance Products
4x484150
Jan 19, 2016 01:07 PM
robbyriot
Jul 26, 2015 08:25 AM
1965HHORunner
Jul 22, 2010 03:10 PM
SOPBeer
Oil & Lubrication
Jul 2, 2009 04:29 PM
SOPBeer
Jun 30, 2009 09:36 AM
