Paint question
Old Jun 26, 2021 | 04:55 AM
Watcher58's Avatar
Watcher58
Unhappy Paint question
I keep finding irritating things on this X. I'm thinking 03 may not have been a good year. This guy baked in the California sun most of its life. When I got it (bought online--and no don't say it!) it was dirty. The pics looked like the paint had a reasonable gloss to it. So I wash it and afterwards I look at it and think this ain't right. The paint is rough as he!!. After 18 years, it's not going to be pristine but it feels like sandpaper. The roof really looks bad. I wiped a spot with acetone and it helped by a noticeable amount. Strangely the passenger side doors and vertical part of the fender are normal. The driver side is rough, except for the crap door paintjob which flakes off. I'm thinking whatever micro brain who did it got overspray on it. So I know I'm into clay, a round or 2 of compound and then wax wax and buff. Does anyone know of an easier way to get that overspray off? I did 1 test spot with clay and it was better but it is going to be one more of a job to do all of that. I imagine a detailer would want 4 figures (I would)
Old Jun 26, 2021 | 04:32 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
the pros who do yachts use Aqua Buff 2000.
https://amzn.to/2StgRR4
equivilant to 1000 grit so it will buff out pretty tiny scrtaches and makes quick work of over spay and such.
best if used with a Dual Action polisher with variable speed.
there are "better" cxertainly more expensive polishers on the maerket but I see a lot of the crews using the Porter Cable. https://amzn.to/2UGYNnn
These foam pads work great with the Aqua Buff Compound
https://amzn.to/3dhfJYa
I use a 18v Milwaukee cordless and it will do the side of my 40' fifth wheel on 1 battery but note that a singe action polisher or grinder can burn the paint fairly easy if you don't use the correct technique.
they can do a larger surface in less time but its actually more strenous work because you have to keep it moving to avoid paint burn. perfect for big trailers or boat hulls not great for your Porsche or even your Ex.
https://amzn.to/35VGi0U
FWIW, I spend my Summers as a kid polishing boats so I tend to chat with the crews down at the docks doing the yacts I work on.
Old Jun 26, 2021 | 04:37 PM
pirate4x4_camo
FTE Remembers
Fwiw, here is the how to for aqua buff.
https://www.bottompaintstore.com/blog/gelcoat/aqua-buff-1000-w-and-aqua-buff-2000/
the spray bottle to mist the surface is key but don’t ket it get so wet it flings liquid everywhere or you risk getting your polishers trigger wet, shocking yourself and falling off the ladder. Ask me how i know
Old Jun 26, 2021 | 09:53 PM
Watcher58's Avatar
Watcher58
Thanks. I'll check that out.
first today
48
Apr 27, 2009 07:22 PM
FordPickMeUp
Paint & Bodywork
Jun 22, 2008 11:37 PM
Doop Oliver
Paint & Bodywork
13
Feb 19, 2007 08:40 AM
Thomsen
Offroad & 4x4
Oct 20, 2006 03:09 PM
TheMachfather
Paint & Bodywork
Dec 31, 2003 09:32 AM
