Fuel Additive
Old Jun 27, 2021 | 11:24 AM
sauerkraut1's Avatar
sauerkraut1
I own a 2000 7.3 that was bulit for what is now high sulfur fuel ..
Replaced 8 injectors at 230,000 miles 2 failed .. Due to lubricity problems ..
Used to use cetane improver/anti-gel only in winter ..
Because of lubricity I now add 16 oz. of 2 cycle oil per tank about 25 gal.
2 cycle oil is low ash so it doesn't build up deposits in the combustion
chambers or on valves .. Hopfully provides lubricity the missing sulfur
used to provide ..
I will still use cetane improver/ anti-gel in the winter for easier starting
fuel gelling prevention ..
Old Jun 27, 2021 | 11:59 AM
Jstamm2001's Avatar
Jstamm2001
Originally Posted by C12H24
The additive guys will be along shortly.
I remember the great emulsifier/demulsifier battle. Lives were lost. Women were widowed. Crops wilted. A memorial has yet to be built.
LOL - I do run an additive, motorcraft- but this comment made my day. Thank you
Old Jun 27, 2021 | 12:51 PM
Brantel's Avatar
Brantel
Opti-Lube...
Old Jun 27, 2021 | 01:24 PM
B-ManFX4's Avatar
B-ManFX4
If you don't use this at every fill up I will see you on the side of the road. How will I find you there? I will simply follow the mushroom cloud !!!
https://www.archoil.com/products/ar6...33195059740754
Old Jul 1, 2021 | 05:55 PM
MyF450's Avatar
MyF450
Thank you everyone. From the many (and varied) responses, seems like some do and some don't. Favorite brands are varied too.
So, I will give it a try using a different brand each time I refuel until I find one I like, or until I decide whether they seem to make a difference or not. I don't plan on spending much time in the really cold climates, so for winterizing purposes, I think that is not going to be necessary.
Hopefully you will not see me on the side of the, but if you do PLEASE don't stop just to say "See? I told you so!"
Sorry about the hornets.
Old Jul 1, 2021 | 08:37 PM
Lamoon78's Avatar
Lamoon78
I been using this stuff for years in my gas and diesel trucks
Old Dec 12, 2021 | 05:25 PM
zeroo's Avatar
zeroo
I’ve used pm-22 or power service maybe 5% of the time in many 100’s of thousands of miles on the cp4 and didn’t realize there was such an overwhelming issue. Guess I need to step up the additive.
Old Dec 12, 2021 | 08:10 PM
JDski's Avatar
JDski
Old Dec 12, 2021 | 08:52 PM
05F250DSL's Avatar
05F250DSL
When I had my 05’ 6.0 I used stanadyne every tank. 187k before I popped the head gaskets. No injector issues. I did also keep up in maintenance which probably helped a lot.
whatever makes you sleep well at night. There’s also the fact if you are trading trucks off every 3 years it’s probably not worth the $$.
KeysMako192
Jul 17, 2020 02:16 PM
wb6anp
Dec 30, 2019 06:38 PM
Vijay
Jul 28, 2015 04:46 PM
jcobb124
31
Oct 20, 2010 04:09 PM
robert kelsey
Dec 10, 2003 09:13 AM
