CLIPS
Old Jun 25, 2021 | 06:42 AM
sbeamer's Avatar
sbeamer
CLIPS
Anyone know if you can get replacement clips for the fuel lines ? Please tell me you don't have to buy the whole line !
Old Jun 25, 2021 | 06:45 AM
The Bone's Avatar
The Bone
A photo of the clip would help a lot.
Old Jun 25, 2021 | 07:07 AM
sbeamer's Avatar
sbeamer
Sorry. I can't get a decent pic of it. It's a blue clip. It is the type you pull outward to unlock, then push in to release it. It is on the right side (facing the engine from the front), right below the 3" aluminum pipe. This is the fitting you remove and rotate up when installing the S&S bypass kit.
Old Jun 25, 2021 | 10:29 AM
Overkill2's Avatar
Overkill2
Supply fitting I'm assuming
This one Scott? I can see it clearly because my oil catch can is sitting on top of the fuse box lid.
This one would work I would think:
Female Quick Connect 1/2 x 1/2 Nylon, 90 Degree Push Lock 8
It's the style that comes with the Air Dog kits. I'm thinking that's a half inch fitting.
They make 3 different ones:
Parker makes the locking fittings also.
These fittings are the J2044 system.
https://www.parker.com/literature/Br...AE%20J2044.pdf
https://www.toyboxtech.com/parker-a6...20group%20%231
The Parker fittings are not cheap.
Old Jun 25, 2021 | 10:42 AM
Overkill2's Avatar
Overkill2
EBay link
https://www.ebay.com/itm/Parker-A624....m46890.l49286
Old Jun 25, 2021 | 04:48 PM
sbeamer's Avatar
sbeamer
So if I buy 1 of these, can I remove the clip and install it in the elbow fitting on the truck ? Thinking it might be easier.
Yes that is the fitting I'm talking about.
Old Jun 25, 2021 | 05:02 PM
helifixer's Avatar
helifixer
not sure the clip is designed to be removed, can you experiment on your old one and figure it out?
Old Jun 25, 2021 | 05:04 PM
helifixer's Avatar
helifixer
and "TEAM DAVE" for finding it!
likes sent!!!! reps sent sounded better.
Old Jun 25, 2021 | 07:37 PM
Overkill2's Avatar
Overkill2
I'm with @helifixer. On this... I don't think that clip is meant to be removable... If you buy the new fitting, I'm thinking you should replace the fitting. You can buy one of those 1/2 inch push lock hose menders to add more fuel line so you have the slack needed after you replace the fitting.
It's what I do... I've been looking into these fittings because once I get the fuel pressure set to 10 PSI on the Air Dog with the mechanical fuel pressure gauge/line once it's installed, I'm going to remove it and replace it with just a fuel line.
EDIT
And thank you!
Old Jun 26, 2021 | 11:15 AM
Fefanatic's Avatar
Fefanatic
I've broken a lot of these over the years. They get brittle over time. Finding replacements can be tough. I now take a tie wrap and interweave it into the connector and secure them that way. Works fine and I have been doing that for over 15 years. They can't go anywhere and do not come loose.
Old Jul 2, 2021 | 07:59 AM
sbeamer's Avatar
sbeamer
OK. So I bought a couple of replacement fittings. They are, "Parker 12mm pushloc push-to-connect elbow quick fitting female SAE J2044 to barb" There's a mouth full. I bought 2 in case I broke 1. I was able to get the clip out and install it into the fitting on the truck. This way, I didn't have to mess with the fuel line. Works perfect! AND, I also found another place, I think it was on Ebay, that had just the clip itself. Unfortunately, I had already purchased the elbows. The 2 elbows were $ 20.90 delivered. The clips are like 8 or 9 $ for 2. The only thing when you are looking for them on Ebay is, YOU have to know what you are looking for. I.E. size.
Bought a couple gaskets from "Cheaper Ford Parts". Their prices are better but,..... they sent 2 of 1 and 1 of 1, the wrong way ! So the one I really need I am short 1. They will take it back, but they charge a restocking fee and YOU have to pay the return shipping too. So I will have a couple items left over to sell to a new home. At least at the local dealer, they take them back for no charge.
Old Jul 2, 2021 | 08:45 AM
Overkill2's Avatar
Overkill2
Pics bro... Pics please. I believe 12mm is the same as half inch. So I would assume you cut the hose where the push lock part was in, then cut it off and pushed the new one on? Did you use anything for lubricant to help the fitting go in?
Old Jul 2, 2021 | 03:15 PM
The Bone's Avatar
The Bone
13 mm is 1/2 inch
Old Jul 2, 2021 | 04:19 PM
Overkill2's Avatar
Overkill2
Originally Posted by The Bone
13 mm is 1/2 inch
Doh!
You are correct but technically it is 12.7mm.
Good catch Bone.
EDIT
Okay I knew I saw 12mm and 1/2 inch listed together before...
This is from the link I listed here: https://www.ford-trucks.com/forums/1...l#post19943380
Brand New Parker A624A58 55 04 Autoline Push-to-Connect Fitting, SAE J2044 to Barb, Composite, Female SAE J2044 and Barb Elbow, 12 mm and 1/2"
Another one here. AND CHEAPER ALSO.
https://www.ebay.com/itm/232860368766?chn=ps
NEW GENUINE OEM PARKER HEAVY DUTY 12MM PUSHLOC PUSH-TO-CONNECT ELBOW
QUICK CONNECT FITTING FEMALE SAE J2044 to BARB
These are quality connectors made by Parker's Autoline division. They are not cheap connectors that will fail. Buy with confidence!
P/N: A624A58 55 04
BRAND: PARKER AUTOLINE
ELBOW CONNECTOR
CONNECTION TO HOSE I.D.: 1/2"
SAVE with this listing PLUS get FAST FREE US shipping!!!
Old Jul 2, 2021 | 07:47 PM
Overkill2's Avatar
Overkill2
End form and barb tail of a quick connect push lock fitting
Okay, so now I'm a little confused. The end form is the quick connector end and the barb tail is the hose end. If you look on the link I provide, you can see they make a connector with a 12mm end form and one with a 1/2 inch end form. They are both listed with 1/2" barb tails.
Anyone know the difference between a 12mm quick connection and a 1/2" quick connection?? I know the size is different but I wonder how to tell the difference between the male connectors. Just looking for more info.
