Warrenty Question
All was good even received a 3 oil/filter and tire rotation deal from dealer.
On the first service on the drive home afterwards, There is a noticed shake starting at around 55mph.
So at home I checked the lug nut to find them not tight after rotation done. On the next trip to town the vibration is still there, So I stopped in at the dealer and asked why this started after their service. Tech looks at truck and runs thru dash display and states there is too much air in the tires and that is causing the problem.
What? then his response is possible out of balance tire, But they cannot do a mounted spin balance so it my problem.
So off to the Tire shop I use and explain the Dealers Tech answer to this, Within 5 mins after they stopped laughing they did a mounted spin test on all 4 tires and all were completely fine balance wise and the air pressure was good at 65 front and 70 rear Is what I run them at when towing the bumper pull 2H trailer, I add to the pressures when dragging the goose neck.
So adding a few more miles on it the vibration is steadily getting worse, When your at 55 or higher you feel the steering wheel shake while holding it but if you release it it will start to shake left/right.
So back to dealer today, The Master Tech and the Service Mgr both drove it and agree there is something wrong.
So I went thru the first service done there and also asked why there is more brake dust on the right front wheel than all the rest so they can check that out also.
The Tech was looking under the front and stated the stablizer was suspect but needs more time to do complete inspection of entire front suspension and steering and brakes.
Meanwhile the Service Manager is on the phone with Ford and they are refusing to cover any work done to it. Their reason is the truck is too new (under 4k miles) or it has been altered or damaged some how.
The truck has never been off road is completely stock except for seat covers I added to keep seats clean and floor mats.
Manager even sent pic's of entire truck including the slightly dusty underside front to rear showing there is no damage or changes done.
They are keeping it to do a full inspection and replace/repair whatever they find.
Now wondering if I should just sell it back to them (they have already asked me twice to buy it because the lot is empty) and walk across the street to the Dodge dealer. Been a Ford owner for more than 50 years.
Has anyone else had a fight with the Ford Service to get their truck fixed?
I wouldn’t put up with that. If the tire shop says the tires are good its Ford’s fault.
On the warranty issue, results do seem to vary from dealer to dealer, and also from Ford as well. The reply that the truck is too new is BS. There are repairs that require Ford approval, and Ford does not always approve repairs, but being too new would not be the reason for denial. It would be nice to know exactly what they believe the problem is. To make a decision, Ford would need that information.
You mentioned that one wheel has more brake dust. After driving, check the temperature of the wheel itself versus the corresponding wheel on the opposite side. If the wheel with more dust is hot to the touch while the other isn't, you have a stuck or dragging brake caliper. That condition will cause a caliper to generate more heat and more dust than the other calipers.
They first requested the steering stabilizer replacement, Ford refused. This was right after 1st oil/rotation service.
With almost a month passing the vibration is increasing in less than 500 miles, so made appointment for service.
Took truck in and both lead tech and manager test drove it, Both feel and see vibration in steering wheel.
Visual inspection of brake dust there is no extra heat on wheel or rotor to touch.
Both have concern of continued driving without complete close inspection of steering and brakes, As they both stated they have never seen this on such a low mileage truck, But something is wrong.
So the wait and see what they find or don't.
Sad less than 5k miles and its under shop arrest, My 73 has over 500,000 miles and is free and still roaming the roads.
Ford is refusing the repair based on it has less than 5k miles so it can not be a worn part.
I know times have changed from the time i worked at a dealership, But I have been turning wrenches for decades and not become a parts changer that some machine said too.
But would it not take less time to replace the stabilizer and test drive it to ensure that it is not a defective part ?
If the wobble is still there put the original back on and search further.
Off to pick up the truck, Time to make a video of the problem and trucks overall condition with Fords response to it and post it online as How the Super Duty has become a Super Dud in under 5k miles with a possible follow up swapping it for a Dodge or Chevrolet!
I wouldn’t open myself up to the aggravation of repeated trips and just put it to stock psi. Clean the truck well. And take it in before trading it.
If you have the camper package, heavy service front springs, or snowplow package you may be experiencing bumpsteer as the front end sits higher than stock. Would need aftermarket help as thats what I had to do with my truck.
I don't think the problem is the stabilizer, that is, if I am actually understanding the problem. My truck had what is considered a bad factory stabilizer, excessive lash, and never exhibited the behavior your truck is. A constant vibration over a certain speed would not be caused by a bad steering stabilizer imo.
It is more pronounced when towing 2 horse trailer as it has weight on rear.
Dropping the tire pressure just give the truck a washing wonder feel as the side walls flex. Not concerned about a soft ride or i would have bought a luxury car.
