Adding factory A/C to '76 High-boy
Old Oct 30, 2003 | 02:25 PM
76  F250 4X4's Avatar
76 F250 4X4
Will I need the wiring harness from a doner with AC and is the AC wiring harness for the AC seperate from the main wiring harness?
Old Nov 6, 2003 | 07:07 PM
Nod's Avatar
Nod
rheacox,check out a couple of online AC Kit suppliers and see what they offer.I used oldairproducts.com but there are more.
Do a search for aftermarket air systems on this site and you should come up with what you are looking for.If you add an aftermarket AC system it can be independent from your heating system or can be tied to it,depends what you want.They come with wiring and control systems also,hope this helps.
"bowties in the rearview mirror"
