Engine bay
Old Jun 22, 2021 | 08:17 PM
Tannerw22's Avatar
Tannerw22
Engine bay
I am finally putting my truck together after 3 years and I don’t remember where everything goes, I was hoping someone could send me a bunch of pictures of the wiring and all that stuff in the engine bay of there EFI 5.8 Windsor xl. Thank you
Old Jun 23, 2021 | 05:59 AM
Chris Rudeau's Avatar
Chris Rudeau
My engine bay is all flipped and modded because of the dual battery setup. Start with the wiring. Once that’s in place everything can only go so far. Lol. What is it your having a hard time with? The metal brackets for the battery trays and such? Or just everything?
the wiring is simple since the main harness plugs into the firewall on the driver side and then wraps around the front. Engine harness plugs in right at the ax compressor. Once that’s all in place, everything kind of comes together.
Old Jun 23, 2021 | 06:03 AM
Tannerw22's Avatar
Tannerw22
Just where certain connections go, like all the hounds and somethings like that and also vacuum lines, I deleted egr and smog pump and I’m having trouble running them all to the right place. I have the green for the get deleted and figured out but there’s a few that I’m a little stumped on. Also there’s a breather on the passenger side valve cover and I’m not 100% sure where that runs too and where the hose goes.
ex3em
Engine Swaps
Jul 14, 2013 03:59 PM
19903934x4
34
Oct 1, 2009 01:00 AM
proverbs_20_24
Jun 18, 2003 01:33 AM
cje07
1978 - 1996 Big Bronco
Feb 28, 2002 11:31 AM
