Trans swap
Old Jun 22, 2021 | 06:47 PM
RedneckNate18's Avatar
RedneckNate18
Trans swap
Working on my 1996 f150 xlt 351w. I bought this rebuilt 1994 trans for my truck being told they were the same only to find the solenoid packs are different. That being said i have done a little research on the subject and have gotten 1 of 2 answers.1: Yes-simply swap solenoids and go and 2: No- the 94 trans is useless to you, find a 95+. Im looking to hear from those who have done it, can the solenoid be swapped and the transmission behave correctly or am i asking for a whole slew of other issues? That being said is the solenoid the only internal part that needs to be changed or the valve body as well? Id like to hear feom those qho have done it but looking for all opinions. Tia
Old Jun 23, 2021 | 08:59 AM
jas88's Avatar
jas88
I put a 1994 trans in a 1996 Bronco and all I had to do is change the plug that goes into the trans.
Old Jun 23, 2021 | 11:24 AM
wwhite's Avatar
wwhite
There are many differences, and the one thing as @jas88 has mentioned, you have to change the plug.
You do not need to change the solenoid pack, it will work but you have to change the plug.
The solenoid packs are different:
- 1994 and earlier have diodes in the pack, the computer does not.
- 1995 and later DO NOT have diodes in the pack, the computer does.
You can use a 1994 diode solenoid pack with a 1996 computer with diodes, no problem.
You CANNOT use a 1995 or 1996 non diode solenoid pack with a non diode 1994 or earlier computer with out diodes, you fry the computer.
Other internal differences are:
- front pump, 1994 E9 casting, 1996 F5 casting, newer pumps more volume
- valve bodies are different, different wormholes different routing
- 1994 does not have center support bearing upgrade, 1996 does have
- basic 1994 have aluminum 3 pinion planetary gears, 1996 may have 4 or 6 pinion steel.
- sun shells different
- other various upgrades differ, springs, clips, sprags, etc.
If the 1994 trans was rebuilt 'properly', with all upgrades, it 'should' include all the upgrades, and be the same as the newer trans.
I would find out if the rebuilt trans has the newer center support bearing, if not, you could be downgrading from what you have.
Urfavplmbr
Large Truck
Jan 30, 2021 04:27 PM
alowfalcon1
Aug 3, 2010 03:36 PM
tcurry
Apr 30, 2003 11:40 PM
