TTB negative camber
Old Jun 22, 2021 | 05:18 AM
Mickw's Avatar
Mickw
TTB negative camber
i have a 95 f150 with the TTB front end, now i know this is a common occurrence and normal but i was wondering if anyone has a fix for the negative camber in reverse. I lifted the truck and did a shake test at 6&12, 3&9 oclock and nothing, no death wobble either. shes pretty firm. I have heard of some kind of camber nut being added, any info or advice as to what i should be looking for?
Old Jun 22, 2021 | 06:31 AM
rla2005's Avatar
rla2005
Get the truck aligned properly and the negative camber in reverse will be minimized. It will not go away completely because of the inherit design.
Old Jun 22, 2021 | 10:30 AM
SFaulken's Avatar
SFaulken
It's not possible to eliminate the wheels crabbing up in reverse. It's just part of the way the suspension works. If it really bothers you, seeing it sitting that way, just plan your parking so you pull forward before you shut the truck off.
Old Jun 22, 2021 | 06:03 PM
Mickw's Avatar
Mickw
Seems like the general consensus. Got an alignment scheduled tomorrow. We’ll see if it tones it back at all
4ninepower
Nov 9, 2013 11:01 AM
nelly781
1978 - 1996 Big Bronco
Sep 27, 2007 10:07 AM
felixr
Apr 26, 2006 12:30 PM
Native Gearhead
Sep 29, 2003 06:34 PM
EPNCSU2006
Dec 30, 2002 09:52 AM
