01 F250 lost throttle control
Old Jun 21, 2021 | 03:58 PM
66+74=?'s Avatar
66+74=?
Leaving a stop sign, tranny had just shifted into 2nd when the dash gauges flatlined and it lost throttle control. Starts and idles fine, shifts into D and R and moves at an idle, but no response to throttle at all. Since it starts and idles, I assume its not the ICM, any chance its NOT the ECM?
Old Jun 21, 2021 | 04:06 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Shorted TCS (Transmission Control Switch) wire in shift lever would be my first guess. It blows the fuse for the instrument panel cluster (which also supplies power to the idle validation switch (IVS) on the accelerator pedal) when the isulation chafes on the top of the steering column where the wire exits the shift lever.
Old Jun 21, 2021 | 04:29 PM
66+74=?'s Avatar
66+74=?
cleatus12r, you are my new best friend! The dash cluster fuse (per the owner's manual)#16 was fine, but the diesel dash cluster is #19....the blown one! a 10 amp fuse got it rolling again so next weekend I get to chase down the short. Thanks for sharing your experience!
Old Jun 21, 2021 | 04:51 PM
helifixer's Avatar
helifixer
just go to ford and get a new shift lever, repairs on a wire that moves that much are temporary.
Old Jun 21, 2021 | 04:53 PM
helifixer's Avatar
helifixer
interesting user name, what does 140 signify?
Old Jun 22, 2021 | 09:58 AM
66+74=?'s Avatar
66+74=?
Once again I thank you for your advice. If you ever find yourself in Western Colorado give me a shout and I'll buy you a steak dinner!
johnfl
General Automotive Discussion
Nov 5, 2023 09:39 PM
PauL3861
Feb 2, 2015 10:15 AM
Dales F-350
Jan 2, 2010 09:34 AM
mkcole
Aug 8, 2008 12:32 AM
