Power Steering Conversion
Old Jun 21, 2021 | 03:50 PM
daleknapp's Avatar
daleknapp
Question Power Steering Conversion
Hi all,
I have recently obtained a new project, on paper it's a 1978 Ford F-150 Ranger XLT.
Front axle looks like it came off an older truck.
I replaced the power steering pump and am in the process of doing a new column and see that I have the "power assist" set up.
Recommendations on how to proceed? I have seen many posts that suggest use of the actual 78-79 equipment.
Best economical/bolt on solution recommendations would be very welcome. Thanks
Old Jun 21, 2021 | 08:51 PM
CurtLarson's Avatar
CurtLarson
Well it’s got the 77 and earlier style steering setup, I’m guessing that’s an 73-75 chassis by my guess. I’ve never seen the hydro assist on a f150 before
Old Jun 21, 2021 | 10:50 PM
Christmas's Avatar
Christmas
A drop pitman arm would help with the geometry.
Old Jun 23, 2021 | 08:55 PM
fordbuddy79's Avatar
fordbuddy79
I guess I will chime in.1st off I have never seen power assist steering on an F150,it was only on a 73-77 F250.The steering box looks like a manual box with a dropped pitman arm, but the tie rod should be mounted from the bottom of the arm not the top.Unless the arm was reamed correctly to accept the end it will have play not work properly.The only thing that I see that is correct is the drag link and trac bar is on the same angle which is what you want.What I would do is swap a ps box and drag link for a 78/79 F150 or Bronco and get rid of the manual box and power assist stuff.
Billy Tinsley
13
Apr 29, 2021 09:38 PM
mbloes
Oct 2, 2018 06:55 PM
Kozo
13
Jul 5, 2018 06:02 PM
Joel1974
Apr 3, 2017 08:45 PM
mk
Mar 27, 2009 09:20 PM
