Sponsored by: Kumho
Aluminum Wheel Edge - Normal?
Old Jun 21, 2021 | 02:34 PM
N147JK's Avatar
N147JK
Dear wheel experts.. I was finally able to find a set of OEM aluminum wheels for my E250. But when I started cleaning them up, I noticed the edges (See attached pictures). The outside edges of the rims are rough, so much so that it has me wondering if this edge is normal or not. Is this the way these wheels were manufactured, or is this some kind of damage? - Thank you in advance.
Old Jun 21, 2021 | 02:39 PM
85e150's Avatar
85e150
MAYBE a little rough with the tire changer.
MAYBE run flat a short distance.
MAYBE from corrosion due to the exposed but semi-trapped area where the wheel and tire meet.
Make sure they are true and the bead surfaces are clean and smooth. Check for cracks, there and in the lug area.
Make sure you get the right lugs.
Run them.
Old Jun 21, 2021 | 03:02 PM
N147JK's Avatar
N147JK
Thanks for the reply. I thought about them running flat or even without tires (!) but that edge is on a bevel such that I don't think it would make contact and wear across the face like that. They are in great condition otherwise. Must be tire changer wear-and-tear on that soft aluminum. They are stamped "Aug 10, 1997" and I'm guessing they have seen a lot of miles. I will file a little of the roughness away and carry on..
Old Jun 22, 2021 | 04:50 AM
JWA's Avatar
JWA
That roughness you're seeing shouldn't affect how well the tire seals against the wheel. I don't know I'd start filing anything just yet--the tire sealing surface seems to be perfectly fine from what I can see. Honestly the roughness you see is just how the wheels were made----probably a million or so of them running around in similar shape.
Old Jun 22, 2021 | 07:33 AM
N147JK's Avatar
N147JK
Thank you JWA. Poking around, I've come across several other sets that look like this, so I'll chalk it up as "typical" and wont worry about it. Now on to polishing!
Bob Ingram
17
Feb 3, 2021 08:35 AM
Pirate Mike
Nov 22, 2017 06:31 PM
OEWheels-Tech
Appearance & Dress-Up
Feb 26, 2017 11:42 PM
Scotty's 52 F3
18
Sep 18, 2015 06:13 PM
whiteboyslo
13
Mar 27, 2013 03:41 AM
