Numbers Don't Lie 3.73 vs. 4.30 Explained
#46
I feel like we are just going in circles here. I am really confused, did the OP just learn how to do math and is wanting participation points or what? Maybe call or email Ford and tell them they should rate the 3.73 trucks to tow more than the 4.30 geared trucks since 3.73s pull better when your in a lower gear with 10 speed transmission, although that has always been true with every transmission, apparently you couldn't do that until the 10 speed came out.
The following users liked this post:
#47
I think the OP's point is we should rethink things because of the 10 speed transmission stretching the power band in both directions. More small steps allows the 3.73 to have plenty of power down low on start ups, although not quite as much as the 4.3. But it gives the 3.73 the advantage at higher speeds where we spend most of our time. That's all while towing. Running empty gives the 3.73 a wider advantage in whole range, unless jack rabbit starts are your priority. Options for all of us, and there is no one perfect option for everyone.
The following 10 users liked this post by Ford8502:
#48
One of the biggest advantages of the 10 speed is to make a small motor feel like a big motor like I have in my F150 2.7 EB with 3.55 gears, geat truck but it has its place. I will take my F350 DRW 2x4 6.2 4.30 gears when I have work to do .
Denny
The following 4 users liked this post by rvpuller:
#49
I see where the OP is coming from with this and as stated above certainly gives options if you don't mind manually shifting and paying more attention while towing. 4.30s give a set and forget tow.
Unless your towing over the trucks "rated" capacity I don't believe you're going to wear the engine out periodically with higher rpms. Besides most people aren't keeping these trucks long term/ high miles.
After seeing the video with the guy pulling the equipment trailer over weight for the F250 with a 3.55 gears in Wyoming 3.73 gears would handle it and 4.30 would shine towing it.
A side note though is, midwest to east coast there really aren't that great of towing challenges of long steep inclines for "mountainous" climbs like you could experience in the west.
#50
It all comes down to what you are using your truck for not weather 3.73 are better than 4.30 gears. In my case because I pull our 16K high profile trailer 75% of the time on both flat lands and high mountain elevations the 4.30 gears are a no brainer because of the added mechanical advantage and it's not just the off the line but the ability to hold a gear before downshifting. Anyone that has pulled hard on grades at elevation knows that whenever you downshift you lose momentum plus the less downshifting the less wear and tear on the driveline. Lots of options out their and buy what you think is right for you but do try and school others on what you think is best for them. There's a lot of heavy towing experience on the forum and we know what works for us and what lasts.
Denny
Denny
#51
#52
WV has steepest grades and sharpest turns that I've navigated.....on roads they consider highways.
The following 6 users liked this post by Kellem:
#53
True story, Sandstone on I64 in WV and Fancy Gap on I77 in VA are two that come to mind. Several of the US highways in WV as well.
#54
Small gears and trucks just don't match, but ford likes them for fuel mileage numbers. My brother had a 91 f150 4.9 with a 4 speed and a 2.73 rear end. Why? No pulling capacity. I bought one with a 3.08 and a 5 speed off a lot and the guy before me used it as a plow truck. Why? Trucks need a bigger gear 4.10 or greater. Went to look at a Chevy last year. Said I want to have a gas engine and pull 20,000 lbs. The guy at the desk said, go somewhere else. The whole notion of 80% of the people buying 3.73 is they don't know any better. Ford is saving money that way by giving you a sterling axle over the Dana. Most folks want their cake and eat it too. You want mileage, slow down. Torque gets you off the line and horsepower keeps you there.... When I ran a 65 ford, 7 litre, I used 4.56 for a reason. Move that mass. It did a great job racing and never missing a gas station. But I didn't care about mileage when a had two four barrels on it!
#55
Most folks don't go as far as figuring all this math out before buying or using and if one did their eyes might just glaze over. Once you drive what ever truck with gears in it you learn pretty fast if you need to lock gears out in particular situations, I always thought the 3.73 and 4.30 are pretty close to each other and unless towing at max in mountainous terrain 3.73 is good enough all around gear.
Looking at the bigger picture of "tow" ratings the 3.73 & 4.30 are equal till you look at the gooseneck/ 5th wheel, then really seperate in ratings at the drw level having the extra rear wheels.
As a fulltime rv'er using my current setup of a 35' 5th wheel at 16k within the GCWR the 7.3 engine would be no problem using 3.73 according to Ford. As the OP said originally just drop a gear or 2 and be in the sweet spot of hp/ torque on a long mountain climb.
For the guys using the 6.2 the 4.30 is almost a requirement to makeup for the lower hp/ torque # compared to the 7.3.
#56
#57
My case is perhaps a little different as I tow in twisty mountainous terrain quite a bit and have always kept trailer size to a minimum, never exceeding 30 ft.
My 7.3 with 3.55 gears is hardly being tested pulling a 7600# trailer and rarely will it exceed 3000 rpms in the hills.
Not so sure I'd feel a significant improvement pulling at only 50% of the trucks capability. Idk
#58
#59
Like you I have traveled and pull trailers in every continental united state and not just the interstate highways, some off the wall back roads.
#60
I can certainly agree with that logic especially when towing in the upper end of trucks capacity.
