Billet valve covers
Old Jun 19, 2021 | 10:20 AM
Edgethis's Avatar
Edgethis
Billet valve covers
I guess these are new. @Khan found them first.
Riff Raff Billet valve covers
They say they'll lower injector noise which would be great, but $1200 is gonna make them pretty exclusive I think.
Who's up for being the first to test...for science and the rest of us?
Old Jun 19, 2021 | 05:58 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Just putting later valve covers on helps a bunch.
Old Jun 19, 2021 | 07:35 PM
Edgethis's Avatar
Edgethis
Aren't they the same valve covers 🤔
Old Jun 19, 2021 | 09:03 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
$1200? I like to get kissed when I get...
Old Jun 19, 2021 | 09:41 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
As far as I have ever seen they are identical, even the same part number from Ford for all 1994.5-2003 7.3L F-Series.
Wow, I always wondered if someone would make a solid billet valve cover for the 7.3L 😎
I have seen them for 6.4L from Beans but never a 7.3L before. That must be a massive block of aluminum to start out.
Old Jun 19, 2021 | 09:45 PM
Edgethis's Avatar
Edgethis
The description says it starts as a 48 lb block milled down to 3 lbs
The only other set of covers I've seen are the fabricated ones from either beans or psp.
I really like the idea of these but that is crazy expensive.
Old Jun 19, 2021 | 09:53 PM
weekendwarriorfsw32
Master of Strokes
The only other set of covers I've seen are the farcated ones from either beans or psp.
Yeah, I have seen the “PSP” that are made by Moroso. They are nice but not $750 for welded sheet metal. When I spoke to Moroso a couple years ago they mentioned they will be selling them direct to the customer and the price would be closer to $400 or something.
I bet Riffraff did them just because they could. No real reason to need billet, but ‘Merica, why not! LOL. The 100 pounds of aluminum per set probably cost hundreds each. I have seen some of the videos they have released of them machining their parts. I would love to see these things being done.
Old Jun 20, 2021 | 06:08 AM
FinnishStroker's Avatar
FinnishStroker
Coating Vcs with raptor or similar is reported to quiet some noise.Same would apply to oil pan.
Old Jun 20, 2021 | 08:38 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
No, the later ones are double-wall whereas the early ones are single. Hit each variety with something and there is a huge difference in sound/vibration transmitted.
You'll get a sharp "ting" (ring like a bell) out of early covers and a dull "thud" out of the later ones. Of course they're interchangeable on the F-series (vans are different) so any 94.5-03 valve covers will work on any 7.3L pickup but there is a big difference in sound transmission between them.
Old Jun 20, 2021 | 09:29 AM
Edgethis's Avatar
Edgethis
I have read about that, but I also see where people have found the stamped covers on the later trucks as well. Complete with appropriate label on passenger side. I can't seem to find anyone selling specifically composite ones.
Old Jun 20, 2021 | 10:12 AM
TheFecalFanatic's Avatar
TheFecalFanatic
I have an early 95, so assuming thin "loud" VCs. I will eventually get a newer set and line with bed liner to quiet things up.
Will have to give them a whack today and see how loud they are.
Old Jun 20, 2021 | 11:30 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yep. I just went out and tested a few.
The 94 and 95 rang out loud and clear. I did not have a set of 96s, but the 97 and up were all just a dull thud.
Old Jun 20, 2021 | 02:25 PM
97-psd's Avatar
97-psd
Those are beautiful. If I dropped the coin on those, some laser engraving would have to be on the list as well.
Since i can’t buy the VCs, I am thinking about one of these:
https://www.riffraffdiesel.com/obs-m...ted-time-only/
Old Jun 20, 2021 | 03:56 PM
Edgethis's Avatar
Edgethis
Just checked my 96, they aren't composite. Used a magnet and it sticks right to them.
I wonder if there's any benefit as far as noise reduction in these over the fabricated ones. I imagine thickness would play a part.
Old Jun 20, 2021 | 04:49 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The stock valve covers are ALL ferrous metal. The earlier ones are just a single piece of stamped steel instead of having sound deadening technology applied.
