Engine Lifting Points
Old Jun 19, 2021 | 12:20 PM
5851a's Avatar
5851a
Originally Posted by fatfenders
Flatty 6 might be the most extreme example. An all iron Ford 300 6 is probably the worst common example due to length though. One helluva lot of leverage.
Did my Dad's 240 on a cheap stand, kept a board under nose end. A 4 wheel stand that was heavier built would have been better.
Old Jun 19, 2021 | 05:45 PM
8pack's Avatar
8pack
Engine on the hoist. Mission accomplished. Thanks for the advice! Now I need to find my engine stand and get it mounted.
Old Jun 19, 2021 | 08:00 PM
38 coupe's Avatar
38 coupe
I am replying to the engine specific thread instead of your truck thread. I agree with the suggestion to do some disassembly. I recommend at least pulling the valve cover, lifter cover, and oil pan. Clean all sludge and decide if you need to go further into the engine. Pull the front pulley and rear main cap so you can replace the front and rear main seals (have to roll the upper half of the rope seal in unless you pull the crank out). Replace all freeze plugs with good brass replacements. Fairly inexpensive gaskets and common replacement parts, but help keep the engine leak free for many miles.
Old Jun 19, 2021 | 08:42 PM
8pack's Avatar
8pack
Excellent suggestions. Thanks!
fishjosh
88
Feb 7, 2022 04:33 PM
FlyJSH
Mar 15, 2021 01:29 PM
genscripter
13
Mar 17, 2018 04:26 AM
TMI
May 1, 2016 10:25 AM
taylor90
Jun 22, 2011 06:40 PM
