How do you drill steel?
I can't seem to make my drill bits last more than a hole or two when drilling steel. I usually have to drill lagre holes between 3/8" and 1", and go through bits like crazy.
Is there a trick or "proper" method to drilling large holes in thick hard steel?
Thanks in advance.
Kevin K.
So, when I have to drill a 3/4" hole, should I just start with a 1/8" hole and go right to the 3/4"? Or, should I go 1/8", 3/8", 5/8", then 3/4"?
Also, most of the bits I buy are the cheap ones. I'm using a hand drill as opposed to a press, so what type of bits should I be getting?
Thanks again.
Kevin K.
A heavy handdrill with lottsa' torque, 12-15amps, at slow RPM less than 300rpm- 180rpm better- I'd start with a 1/4" bit first it will let the point of the 3/4" bit cut directly into the steel cavity. Important to hold straight (perpendicular), no wobbling to save the bit & your strength, sit on the drill top handlebar if you can. If the work is vertical I've strapped myself to it to get a better purchase. Ya may want to go 1/4", 1/2", then 3/4", depends on you & the drill.
'Cheap' HSS bits are ok if your cutting mild steel, forget it in hard steel gotta use TiN or Carbide bits.
There is no question he has drilled ~plenty~ of those $*&#$ holes.
I was going to recommend a torch. I have drilled plenty of them too
If you're "going through drill bits like crazy", and you do a lot of drilling, I suggest you buy yourself a thing called "The Drill Doctor", with the special chuck to handle drill diameters up to 1" (the standard unit handles up to 1/2"). The regular Drill Doctor runs about $100.00.
This device allows you to resharpen your drill bits, and is very easy to use. It'll sharpen regular points, split points, and masonary bits regardless of composition (HHS, carbide, titanium, etc). I used to buy new bits whenever one got dull, but not anymore! As long as there's any fluting left, you can sharpen that sucker BETTER than new because you can increase the rake angle beyond standard if you want. It took me several tries to get the technique down right, but once you understand what you're doing you can resharpen a bit in just a minute. Amazing how much money this will save you, and you always have very sharp bits available. No other bit sharpener even comes close to this device - and it saves so much
aggrevation and frustration.
I recently had occasion to do some volunteer work constructing some rather large playground equipment (it took 50 volunteers/day for over a week), and was told in advance that priority items to bring along were 1/4" & 3/8" "peashooters" and bit sizes (if I had any). I took along my battery operated drill, and about a dozen freshly-sharpened bits of each size (had PLENTY I'd replaced over the years but never fert right in throwing away). Saw guys pushing their guts out trying to drill, their bit just a-chattering & squealing away trying to punch the holes in the pipe-type uprights (you know the scene), and them cussin' & swearing under their breath. I'd hand them a bit of mine, and they couldn't believe how it cut - very fast and smooth with very little pressure. Many commented they'd NEVER used bits like mine, and asked what the secret was. My bits were the talk of everyone who used one.
One doofuss snapped two bits when he "broke through" the pipe wall and twisted the drill sideways like a pry bar in the hole. At the end of the day, I just took the bits home, ground the flute end flat on my bench grinder, and resharpened it on the Drill Doctor. One broke about 1/2" from the non-fluted shank and I was able to recover the piece that broke off. I sharpened what was left on the shank, as well as both ends of the piece that broke off. Made three bits out of one, and used those the next day at the playground too! The "double-ended bit" raised a few eyebrows, I must say.
Yes, drilling technique is important - relatively slow speed and lubrication if you're honkin' through big thick stuff with a larger diameter bit. I used to drill pilot holes, too, but once I started using the the Drill Doctor, I find I don't need to. I only need to centerpunch to start the hole where I want it. And if I can grind a splitpoint just right on a resharpened drill, most of the time I don't even need to centerpunch.
You can buy the Drill Doctor at Home Depot, Sears, etc. Makes for a real nice Christmas present, too. That's how I got mine (after I asked Santa for it in my annual letter)!
There's a thread on this board entitled "Tools you can't live without" or something to that effect. In this business, the Drill Doctor may not may not be #1 in my book, but it's darn close to it!
A big 10-4 to Traderjoe and the Drill Doctor. It makes for much easier drilling in any steel. I have use of the small unit so I can't do the split point, but my Doctor will be the bigger unit when I get my own( my Dad is letting me use his!).
Forgot to mention the cutting oil, buy some actual cutting oil and use it!! It makes the bits last longer and cut smoother and faster.
Back to the bench grinder...
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Pat Corbin
alot of "cheap" drills have too much rake ground on them for drilling steel, they will chatter, grab, and break or dull the cutting edge.
like everyone else says, don't turn it too fast ( if your chips are turning blue, it's too fast) step up you holes(makes life alot easier with a hand drill) and you can use cutting oil, if you so desire, it will increase your bit life.
