2019 - 2023 Ranger Everything about the new 2019-2023 Ford Ranger.
Oil
Old Jun 16, 2021 | 01:29 PM
F350MS38RSSA's Avatar
F350MS38RSSA
Oil
What oil are you guys switching to at your 1st oil change? I have a 20 Ranger.
Old Jun 16, 2021 | 01:32 PM
ford390gashog's Avatar
ford390gashog
The brand is irrelevant, pick a oil that meets the WSC specs as laid out in the manual.
Old Jun 17, 2021 | 10:39 AM
reddog99's Avatar
reddog99
I'm using Mobil 1. With a turbo, the engine really needs a more heat resistant oil.
Old Jun 17, 2021 | 10:41 AM
F350MS38RSSA
When did you switch to it? What mileage?
Old Jun 18, 2021 | 09:22 AM
James David's Avatar
James David
I let the dealer service my truck. It's cheap enough. They use Motorcraft synthetic blend I think.
Old Jun 18, 2021 | 09:46 AM
ford390gashog
This would apply if the turbo wasn't water cooled as this was a very real issue on turbo has engines decades ago.These days you won't see center cartridge temps on the turbo exceed 350 degrees. The turbo is the least of the concern LSPI and fuel dilution are the biggest issues.
Randy777
Mar 27, 2012 03:23 AM
ASE
Aug 30, 2004 01:53 PM
86bronco2jeff
Oil & Lubrication
Mar 25, 2003 11:32 PM
