Defrost default
Old Jun 15, 2021 | 03:29 PM
Joe Monaghan's Avatar
Joe Monaghan
Defrost default
Hey guys need some help. My 2002 EX 7.3 diesel has defaulted to the defrost mode. My EX sits a lot and I’ve been restoring it slowly. So last year it did same thing and I replaced the vacuum solenoid. That fixed it. Now it’s right back again at defrost default. Vac. Pump runs non stop. I have lock out hubs so I plugged the red line at solenoid. Still same. I unplugged black line from pump going to reservoir and put finger over fitting on pump for 5 minutes and pump never cut off. I’ve traced down all lines on engine and they are good. I’m thinking the pump may just not be pulling enough vacuum. Any ideas?
Old Jun 16, 2021 | 12:50 AM
HorsePower Junkie's Avatar
HorsePower Junkie
Hi Joe,
I have a 2002 7.3 and having same issue.
Where is the vacuum solenoid located that you replaced? Can you post a pic of it please?
Thanks
HPJ
Old Jun 19, 2021 | 01:02 PM
SmackDaddy's Avatar
SmackDaddy
You probably have a leak. If your front hubs do not engage the seal is leaking.
Old Jun 19, 2021 | 04:10 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Originally Posted by HorsePower Junkie
Hi Joe,
Thanks
HPJ
it’s located on the passenger inner fender wall just behind the battery on a gasser, not sure on a diesel, but should be I a similar location.
ahousne
Aug 1, 2016 07:05 PM
jeem
Jun 28, 2013 06:40 PM
timf150
Nov 5, 2012 09:12 PM
semperfi350
Apr 16, 2011 05:19 PM
Olddog66
Sep 20, 2010 10:48 AM
