Rewiring 7.3 trannie??
Old Jun 15, 2021 | 11:52 AM
Beto Gray's Avatar
Beto Gray
How hard is it to rewire a transmission? Guy has a 95 f250 7.3 that im looking to maybe buy. He said the only thing wrong with it is the trannie wiring. Apparently he had/has a chip and had to "un-marry the trannie wiring." I assume all id have to do is rewire it, or soder the wire back together.
Old Jun 15, 2021 | 01:02 PM
Conanski's Avatar
Conanski
What are you trying to do here? If you just need a trans then the vehicle wiring that he hacked up is irrelevent, if you're looking for a wiring harness look elsewhere.
P.S.
Ok I think I misunderstood originally, you're looking at buying the truck not just the trans.
The sellers description of the problem doesn't make a lot of sense, the only thing computer controlled in that truck would be the trans and a chip plugs into the computer so there is no reason to alter any of the wiring. My guess is the truck in general is a hack job so you're probably better off avoiding the headache completely.
Old Jun 15, 2021 | 01:32 PM
Beto Gray's Avatar
Beto Gray
That's kind of what I'm trying to figure out. The only chips that I've seen for it you unplug the ECM and plug it in between the ECM on the firewall. So I'm not real sure what happened.
Old Jun 15, 2021 | 07:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
1995 was the first year of the Powerstroke. Both the engine and transmission are computer controlled.
Old Jun 15, 2021 | 08:05 PM
Beto Gray's Avatar
Beto Gray
So my guess is that he got a chip that wasn't 95 year specific, or something.
Edit* my thought was OBDII started in 96. So maybe it was for OBDII.....
I'm tempted to at least go look at it.
Old Jun 15, 2021 | 11:33 PM
wwhite's Avatar
wwhite
Some have hacked up a single switch to control torque converter lockup/unlock.
That is messing with the wiring.
Go look at truck, and take pictures of what the mess is, post them back, then we will all know.
Old Jun 20, 2021 | 08:31 AM
Beto Gray's Avatar
Beto Gray
They end up selling the truck before I could look at it
Sorry for not up dating sooner
meanjoelake
17
Dec 19, 2011 02:09 PM
skoto1
Feb 8, 2008 04:45 PM
