Speed Limiter/Govenor
Old Aug 10, 2023 | 03:54 PM
  #31
number9xd's Avatar
number9xd
It apparently can be done via Forscan (somehow). There's a couple threads on it over on Tremor Forum and a couple guys confirm they've done it, but not been real specific about which settings they changed to make it happen. I've done a little looking and testing but not found a setting that works on my truck yet. This thread also has some information in it that may be applicable (?) https://www.fordtransitusaforum.com/threads/factory-set-or-factory-option-speed-limiter.81785/page-2
Old Aug 10, 2023 | 06:17 PM
  #32
pdumpbody's Avatar
pdumpbody
Some of the Super Duty trucks come from the factory speed limited to 75 mph
Old Oct 23, 2023 | 01:34 AM
  #33
anyoceans's Avatar
anyoceans
Only if they can provide specific proof the mod or change was a causal factor.Over speed wont damage anything, while over rev will. Be careful what you change.
Old Oct 23, 2023 | 10:48 AM
  #34
leadmic's Avatar
leadmic
Thr top speed an be changed or removed with FDRS.
Old Oct 23, 2023 | 03:44 PM
  #35
redford's Avatar
redford
FTE Leadership Emeritus
My observation is that driving faster than 70MPH really kills the fuel economy. If you want to spend the money, good on you.
Old Oct 23, 2023 | 04:33 PM
  #36
Joe T's Avatar
Joe T
Originally Posted by redford
SRW trucks are limited due to tire constraints. I have been told that DRW trucks are limited to a lower speed due to limitations in the driveshaft speed/RPMs.
My f350 dually is the same as my srw’s at 96.
I have seen the f250-350 tires in different factory sizes and brands advertised at 106mph and 112mph max speed ratings.
The 450 pickup is 87mph max on the factory tire, I believe, but check before you try.
Old Oct 30, 2023 | 12:25 PM
  #37
Kljm's Avatar
Kljm
2nd Gear
Old Oct 30, 2023 | 03:03 PM
  #38
Pickupmanx2's Avatar
Pickupmanx2
My '22 F550 CC/4x is limited to 76 and it sucks when you want to get around some cidiot on the 99 or the 5, or want to go up a hill faster than 50mph with a load 🙄 I called Banks and supposedly the derringer will be available for the 22 F450/550's around the first of the year, looking forward to that!
I have programmed/chipped all my newer trucks I've had and have been happy with them all, no, not a waste of $$
Old Oct 31, 2023 | 06:23 AM
  #39
ssls6's Avatar
ssls6
On a 2WD maybe, on a solid front axle? never.
Old Oct 31, 2023 | 07:39 AM
  #40
'65Ford's Avatar
'65Ford
I've never cared how heavy folks load their trucks or how fast they drive them...on private property. I (along with most folks) don't want to share the road with heavy loads driven at ludicrous speed.
Old Oct 31, 2023 | 10:51 AM
  #41
DPelletier's Avatar
DPelletier
I could see a 76mph limit for the C&C trucks being a problem but 96mph is fine for me with my dually. I didn't like the idea of my Jaguar being artificially limited to 300km/h (186 mph) either but it turns out I never hit the limit anyhow! LOL
I can see the tire ratings being the reason for the limits; I don't buy the driveshaft/rpm thing.
Dave
Old Oct 31, 2023 | 07:24 PM
  #42
Sport45's Avatar
Sport45
It's a real thing. Google "What is driveshaft critical speed" and you'll read things like this:
What is critical speed & why is it important?
Most important is the Critical Speed. Essentially, any rotating shaft will reach a point where it will become dynamically unstable. This leads to a “whipping” or “jump-rope” effect that causes violent vibration and ultimately leads to driveshaft failure. Critical Speed is a function of the shaft’s length, material stiffness and tubing diameter.
And driveshaft critical speed calculators like this one:
Spicer Driveshaft Critical Speed
Spicer has this to say: "In short, you never want the 1/2 criticalspeed of the driveshaft to occur within the 50 to 70 MPH range of the vehicle. WARNINGS. An unbalanced driveshaft can experience a criticalspeed failure..."
All that said, I will freely admit I have no idea what the critical driveshaft speed is for any Ford Super Duty. It may not occur within the speed range our engines are capable of. But maybe it does?
Old Feb 8, 2024 | 07:57 AM
  #43
speakerfritz's Avatar
speakerfritz
gee...I wonder why there is a speed limiter....maybe ford knows something that they anit telling.
Old Feb 8, 2024 | 10:58 AM
  #44
TexasJackKin's Avatar
TexasJackKin
[QUOTE=DPelletier;21020882]I could see a 76mph limit for the C&C trucks being a problem but 96mph is fine for me with my dually. I didn't like the idea of my Jaguar being artificially limited to 300km/h (186 mph) either but it turns out I never hit the limit anyhow! LOL
Critical speed is a real thing, when I was working overhauling big steam or gas turbines, bringing them up to speed was a dicey process. You'd bring it up to 10% below the first critical speed, then push it though to 10% above and let it run a while, then bring it to 10% below it's second critical speed, then push it though usually to final running speed. The shaking going though the criticals was exciting. the main shafts were 12 inches solid steel, the vibration monitors would indicate a "U" shape at the first and a "W" at the second.
The first few times it can be a bit unnerving, but you learn not to let them run withing 10% of critical speed. They have the same issues coming down in speed, the same as going up in speed. All that said, I have no idea what the critical speed on a super duty truck driveshaft might be.......
  #45
saratoga2011's Avatar
saratoga2011
A 2013 6.2L F250 with factory LT275/65/20 tires will definitely exceed 120mph and it pulls pretty hard up to that point.
I would imagine the newer trucks are capable of going 130+ no problem, all safety concerns aside.
