Sponsored by: Auxito
Lost spark after heavy rain
Old Jun 13, 2021 | 05:48 PM
Aaron44221's Avatar
Aaron44221
Hello,
So this JackAss (that being me) was driving through a downpoor and killed it with the clutch and couldn't get it to restart. Tried to start it and could not get it to fire so I tried using starting fluid with no luck I'm getting it started so I'm assuming I lost all Spark any ideas of why I lost Spark any help would be great thanks
sorry guys it's a 1998 Ford F150 with a 4.2 L
manual tranny
Old Jun 13, 2021 | 06:12 PM
Jon Freeman's Avatar
Jon Freeman
....so I'm assuming I lost all Spark
--have you actually checked to see if spark is not there ?
--Check for codes
Old Jun 13, 2021 | 10:28 PM
Aaron44221's Avatar
Aaron44221
--Check for codes
only by doing so sticking a screwdriver in the end of plug wire holding it against of close to metal. I do not have a spark tester or trouble code reader im going to rent one tomorrow to see what codes are present I had taken the battery out to re charge last nite so whatever codes are showing now should directly be linked to this issue correct?
Old Jun 13, 2021 | 11:20 PM
Jon Freeman
If you removed the battery then the codes will have been erased .
Old Jun 14, 2021 | 06:18 AM
Aaron44221's Avatar
Aaron44221
Originally Posted by Aaron44221
Hello,
manual tranny
[QUOTE=Jon Freeman;19925788]If you removed the battery then the codes will have been erased .[/QUOT
Sorry guys I was wrong im getting spark no fuel was able to get it to start using starting fluid so im having a fuel issue I suppose can anyone tell me about the fuel pump driver module??? Or maybe something else I cAn check
Old Jun 14, 2021 | 08:56 AM
Stonedpony's Avatar
Stonedpony
Check your fuses and see if the fuel pump one is working, If by chance the fuel pump has never been changed I have seen new ones go bad. See if you can hear the pump come on with just the key turned on for 2-3 seconds. When was the last time you changed the fuel filter? Have seen those so bad the truck would not run. (Loved the lady's comment: I thought those didn't need changing as it is just a filter. The truck was 8 years old.)
Just changed a fuel pump in an F150 3 times because of the pump, float, and too much pressure and the funny part was they were all new out of the box. (Pressure was over 100 PSI at the rail. Would have been a very good diesel pump with that kind of PSI. Surprised the heck out of me with that kind of pressure.)
Old Jun 14, 2021 | 09:33 AM
projectSHO89's Avatar
projectSHO89
You don't have one...
Start with checking the inertia switch. After that, it gets harder and requires actual diagnostic work.
Old Jun 14, 2021 | 12:24 PM
Glcooper's Avatar
Glcooper
I have an 02 that would not start after a good rain. I t ended up being the fuse block under the dash was getting wet. Replaced windshield(leaking) and new fuse block and all good
Old Jun 23, 2021 | 11:15 AM
ChadInCanada's Avatar
ChadInCanada
I would check the fuse panel area for wetness and the front passenger floor area. The computer is in the front passenger kick panel area. Let's hope it is just the fuel pump...
Cbartlett1988
17
Jan 2, 2016 10:29 PM
copuntryboy
1997 - 2003 F150
Mar 12, 2012 01:04 PM
johnnyhomz
Mar 15, 2011 05:44 PM
johnnyhomz
2004 - 2008 F150
Mar 14, 2011 05:13 PM
jackfast1
Dec 3, 2007 08:41 AM
