EGR Restoration
Old Jun 13, 2021 | 04:08 PM
bkrummy's Avatar
bkrummy
EGR Restoration
A PO of my truck deleted the EGR system, and I'm trying to restore it back to OEM function. Does anyone have a reference that I can look at to do this? Would it be in a Haynes manual perhaps?
Thank you.
1988 F150 XLT Lariat 4x4 351w
Old Jun 13, 2021 | 07:08 PM
sswari's Avatar
sswari
The Manuals probably would not have an actual how to on putting it back, but it would be a good reference for what should be there.
The hard part is to know what all the PO actually took out, from what I have read, there are a few different levels of the Emissions delete.
Old Jun 13, 2021 | 07:47 PM
Conanski's Avatar
Conanski
EGR is pretty simple on that motor, the tube connects between the pass side exhaust manifold and the EGR valve that is mounted on the upper intake behind the TB. A vacuum line runs from there to the EVR solenoid right below the coil, and that solenoid gets manifold vacuum. There are also electrical connections at the EVR and the position sensor on top of the EGR valve.
SatinBlack03
Apr 28, 2015 10:01 AM
olfordsnstone
Aug 20, 2013 11:14 PM
the_sharkster
Mar 7, 2007 02:04 PM
