p228E p0093
Old Jun 12, 2021 | 03:38 PM
snakedoc's Avatar
snakedoc
p228E p0093
Have a 2012 f450 chassis truck 6.7 105k miles delete for several years. Just had a issue the truck just cut off no limp no warning just off stop it restarts fine, this happed 3 times before I go home, pulled codes p228e p0093. No leaks but the crazy part is of you drive hard it doesn't die if you are below 45 is dies alot. I have a spare 6.7 engine so 1 at a time swapped every sensor regulator fuel control valve and new filters motor craft. No change, can't see any metal in the sensors i even cut the filters open no contamination can be found. The low pressure warning never comes on just cuts off. I not sure what it i over looking think I'm going to put a lpfp on it and I don't see and signs that the hpfp is bad.
Old Jun 13, 2021 | 11:30 AM
senix's Avatar
senix
if you use an additive and the little plastic piece in the cap of the bottle falls into the tank, then you may have a blockage in the pick up tube.
Old Jun 13, 2021 | 07:13 PM
snakedoc's Avatar
snakedoc
But I would think that the lpfp low pressure message should come on plus the hard you drive it runs better. I'm probably going to drop for tank as I use a additives just to be sure.
Old Jul 10, 2021 | 02:34 PM
snakedoc's Avatar
snakedoc
Dropped tank found nothing cleand checked pickup line. New fuel pump, no change still cutting off. Not sure what to try next.
Old Feb 24, 2022 | 03:20 PM
SuperDutyFan95's Avatar
SuperDutyFan95
4th Gear
Did you ever figure out the issue?
Old Feb 25, 2022 | 04:57 PM
Overkill2's Avatar
Overkill2
I did a little research for you on the P0093 code. Watch this video.
Old Feb 25, 2022 | 07:24 PM
SuperDutyFan95
4th Gear
Thanks, got a new complete drivers side fuel rail assembly coming next week so we'll see what happens. Truck has new HPFP and runs prefect till it doesn't haha so we'll see how it goes.
Old Feb 25, 2022 | 11:24 PM
Overkill2's Avatar
Overkill2
Hopefully it's just that fuel pressure regulator like in the video. Think positive!
Old Oct 17, 2022 | 08:26 PM
Ronschill's Avatar
Ronschill
1st Gear
Did anyone figure out what it was I have the same thing going on with my 2011
Old Oct 18, 2022 | 11:11 AM
SuperDutyFan95
4th Gear
Replaced the drive side fuel rail assembly with the regulator pre installed and it solved our issue. This issue was happening after we replaced the HPFP due to stalling when coming to a stop. After we replaced the HPFP it ran great but when going WOT up a hill for 15-20 seconds the truck would shut off and throw these codes. Then would restart and be fine till you got on it again. The new rail assembly fixed it.
pbeamtn
15
Aug 4, 2019 07:29 PM
DItR
20
Oct 22, 2013 09:40 AM
yeomansjon
May 21, 2012 09:55 AM
Kargh
24
Nov 27, 2010 02:10 AM
SHOpar
1983 - 2012 Ranger & B-Series
Mar 31, 2003 08:59 PM
