idle control
Old Oct 30, 2003 | 01:39 AM
patuca's Avatar
patuca
idle control
this may be a dumb question...but how do i adjust the idle control settings on my truck? right now it kicks up to about 1100 to 1200 rpm in the cold weather. i've been reading some posts here and everyone seems to have their own thoughts on what to set the idle at. can i leave it where it's at or should i bump it up a little? thx.
Old Oct 30, 2003 | 01:42 AM
johnsdiesel's Avatar
johnsdiesel
You can't adjust the idle unless you buy/make an auxillary idle controller. If you buy one you can get one for as cheap as $150, if you make one you can do it for $20 worth of parts.
Old Oct 30, 2003 | 02:21 AM
patuca's Avatar
patuca
johnsdiesel,
i may be mistaken, but i'm pretty sure that my truck already has an auxillary idle controller. when i start it up in the cold morning and let it idle a few minutes, it will kick itself up to a higher rpm....am i mistaken about this? thx.
Old Oct 30, 2003 | 02:45 AM
johnsdiesel
That's not an auxillary idle controller, that's a built in program that came from the factory. If you had an auxillary idle controller it would be mounted somewhere inside your truck by the dash and plugged in near the bottom center under the dash. Unless you have a visible device you don't have one.
Old Oct 30, 2003 | 06:44 AM
powerstroker250's Avatar
powerstroker250
patuca,
That is the cold ambient package built into your pcm.
Old Oct 30, 2003 | 05:24 PM
patuca's Avatar
patuca
ok, i see. thanks for setting me straight there. so much to know so little time. bear with me here.....i ran some psd's where i used to work...they had power take off's installed to supply the gusto for a hydraulic water pump in the bed. in the cabs, right next to the shifter were units allowing a person to set idle and so forth while operating the pto and pump. is that little electronic gizmo what you all are refering to when you say auxillary idle controller?
Old Oct 31, 2003 | 07:56 AM
powerstroker250
Yes. And it is also called the APCM(auxillary powertrain control module).
moosey78
Nov 26, 2013 05:40 AM
frmach
1997 - 2003 F150
Nov 10, 2012 12:41 PM
neb0244
18
Sep 2, 2010 04:06 PM
ResJudicata
Dec 24, 2008 05:18 AM
