08 ranger engine problem
Old Jun 9, 2021 | 01:45 PM
mark a.'s Avatar
mark a.
This truck has developed a kind of surge or bucking at low rpm. It's a 4x4 5 speed 3.0. It only does it when its rolling, lugged down in a gear starting out. I don't notice it starting from a stop and running up through the gears. When making a slow turn in a intersection and then getting into the throttle it will buck just a few times till the engine and vehicle speed get up. It never stalls and idles fine. If your driving down the road and floor it, it doesn't do it. It hasn't gotten any worse in the 2 weeks it's been doing it and there are no codes. I haven't had a fuel psi gage on it yet.
Old Jun 9, 2021 | 10:15 PM
pawpaw's Avatar
pawpaw
Seeing that its a engine load occurrence, suggests a spark problem. Like excessive plug gap, causing a wimpy spark that blows out under heavy engine load.
Old Jun 10, 2021 | 06:17 AM
Kruse's Avatar
Kruse
I second Pawpaw's answer. You didn't mention the mileage on this or if the plugs had ever been changed. If there's any doubt, change the plugs (with Motorcraft), fuel filter and possibly the wires.
Speaking of plugs, my '98 3.0 has 100K on the plugs, just started to experience the same conditions and I need to give it some attention.
Old Jun 10, 2021 | 10:37 AM
pawpaw's Avatar
pawpaw
^+! on Kruse's more in depth thoughts.
Old Jun 12, 2021 | 01:11 PM
mark a.'s Avatar
mark a.
The new spark plugs solved the problem. They all had a 1/16" gap. I thought that it would have shown a misfire code though.
Old Jun 12, 2021 | 03:38 PM
pawpaw's Avatar
pawpaw
OK, good find, fix, feedback & to hear new plugs seems to have put things right.
Seeing as it wasn't misfiring constantly, maybe it didn't happen often, or long enough to aggravate the computer enough to turn the CEL on, But it may have stored a Pending code, so did you scan with a code reader or scan-tool???
Old Jun 13, 2021 | 03:09 PM
mark a.'s Avatar
mark a.
A scan tool.
GeoMan
36
Aug 18, 2004 10:40 PM
MyDangerRanger
3.0L V6
Oct 7, 2003 07:45 PM
moose_hill
Sep 22, 1999 03:07 PM
