Distributor
Old Jun 8, 2021 | 11:37 AM
MrGGermany's Avatar
MrGGermany
Distributor
Hey all, I'm trying to swap out the reluctor wheel and the pickup coil in the distributor. There is a roll pin holding the reluctor on and I can't get it to budge by prying on the bottom with a flat screwdriver. Does anybody have any way to get the roll pin out? I was thinking of trying to start a screw in there and pull, but I'm not too confident that that'll work.
any and all ideas would be greatly appreciated.
Old Jun 8, 2021 | 12:27 PM
46Whizzer's Avatar
46Whizzer
Use two screw drivers 180 degrees apart and pry up on the reluctor wheel evenly.
Works every time.
Old Jun 8, 2021 | 06:27 PM
440 sixpack's Avatar
440 sixpack
Yes pry it up, and a little WU-40 helps.
Under that you'll find a tiny ring holding the pickup coil down .
Hang onto your old parts. I had 2 bad Standard brand pick up coils in a row so if you're replacing it with a chinese one your old one might be better.
Old Jun 8, 2021 | 06:39 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on use to flat tip screwdrivers and make sure you do NOT bend the arms or the reluctor wheel. Just in case you need to reuse it. Also do not lose that roll pin either. Put a piece of small wire down in it as you pry up on the reluctor to help catch it. I also hear you can use a small gear puller on the reluctor wheel. Then yes a snap ring is under that to hold the plate on.
Old Jun 9, 2021 | 05:49 PM
MrGGermany's Avatar
MrGGermany
Great info guys... Thanks! I'll see if I have a small puller, if not I'll try 2 screwdrivers.
SteveH123
Sep 21, 2016 04:59 PM
jimlj
Oct 17, 2005 08:47 AM
jheroux
Apr 8, 2005 10:25 PM
dillon1033
Feb 9, 2003 12:52 PM
babybroncoii
Bronco II
Oct 29, 2001 03:31 PM
