1983 ford F 150 charging issues
A vacuum hose has come off or cracked. Something like that. Remember everything you did. I know you were messing with the wiring and the alternator, but I doubt that is causing the problem. If you want to make sure, put your meter on the + wire of the coil, and the engine block. You should have at least 9v on the coil + when the engine is running.
thekingofcows
27
09-23-2019 10:14 PM
joshofalltrades
Electrical Systems/Wiring
11-30-2012 02:58 PM
