When I started my '00 5.4 Expy today, all the gauges (tach, voltage, oil press, etc...) read the normal ranges and then zeroed for a few seconds before returning to normal ranges. I think that I have read here that this may indicate a weak battery. I wasn't able to find the thread on a search. Has anyone seen this problem? Did a new battery take of it?
My battery is from the factory, I have had the truck 48 months. I live in Florida and know that the heat is hard on batteries. Your responses are appreciated.
It's the battery. The guage sweep is a sign that the engine computer is being deprived of enough voltage to retain it's memory of stored operating parameters while the engine (and therefore alternator) is not operating. The same thing would happen if you disconnected a healthy battery for a period of time, hooked it back up, then turned the key to the run position.
Thanks PaulC...that's what I thought. I hope it starts in the morning, or I'll be stuffing my family into the Acura sedan. It looks like battery replacement will be my project for tomorrow.
Thanks for the responses. I bought an Exide. I had good luck with one in my other car. I probably could have done better with the warranty. Its an 18 month free replacement with 72 month pro rating. But, for $55, I should be able to get my money's worth out of it. The gauges did one sweep maneuver when I first started the truck, but operate normally now....problem fixed. Thanks again PaulC for the quick response.
Ditto - got a 75-month, 650 CC amp battery for the Expedition yesterday from an Interstate Battery store for $87 (before tax) which included free installation and some TLC for corrosion on battery cable terminal clamps. Although I could have replaced the battery myself, you cant beat free installation and The guy also replaced a corroded terminal clamp as well as added some felt washers - total came to $104 with with tax. Local Ford Dealer wanted $89 plus another $35 to install the Motorcraft battery.
FYI - both the Interstate battery and the original MotorCraft battery that it replaced, had a "Johnson Controls" trademark logo embossed in an inconspicuous place on the plastic case of the battery!
