My "06 is consistently below 10* spread. I see closer to 5*. If I was seeing 10* I would think it could be better and replace the cooler. Just depends on how much plugging of the cooler you are comfortable with and your energy level to go back in again if the temps creep up some more. When/if I replace my egr cooler, I will fork out for the Bullet Proof Diesel one as recommended here many times.
Have everything a, cleaned up and ready to put back together.
I’m having a nagging in my mind about head gaskets.
As mentioned in first post, $265k on the clock. I have never pulled heavy for any length of time, until EGR failed truck was running well with normal running temps in the 195-200 range.
I know it’s a matter of time before the gaskets need to be replaced.
Thoughts on just installing ARP studs before they blow or just pull the heads, have them surfaced and then install new gaskets and ARPs?
