Ford 400 build with meyer pistons
77 HOS's subsequent pictures made me look again, and this time I enlarged the picture, and sure enough, they aren't flat tops.
Sorry for the time wasting.
Run your numbers again with a NEGATIVE 0.016 and you should get an SCR of 11.19, and a DCR that is still too high.
Your first mistake was buying pistons that weren't what you expected.
The second bigger mistake was not mock assembling the engine (after a .04 bore and hone) and measuring the decks first, and then stripping it all back down ready for machining.
But you know that now.
Your existing cam spec suggests that you want a street driven truck that does not detonate, gives nice torque and power, and is as fuel efficient as one can get with a 1970's V8..
If you continue with those pistons, and manipulate the gasket height, you won't get what you want, and you will have to buy shares in an Avgas company !
You'll be a happier man if you wait for custom pistons that have been made to YOUR EXACT specs, and choose a cam with an IVC etc that gives the engine a detonation free package.
I honest thought it was designed to mate against the head surface pointed to below. Don't get me wrong, These pistons would work with OC heads but with a 62cc trick flow i think there is a better option. The stepped area that is .065 in the hole along with a .050 gasket is giving detonation a place to happen. If there is no place to encourage detonation it is much easier to manage with today's fuel.
(Or measuring the 'old' engine before disassembly, and comparing measurements to the new pistons. Much easier. LOL)
I will update when i get a quote. I am hoping RT can find this piston from a previous customer in their file. it has the correct shape to match the TF head. Only issue is the compression height at 1.518. i need 1.70 (i think)
When you remove the pistons and measure ALL of the piston compression heights, and deduct the 0.016's, or whatever, from them, you'll know exactly what you need to get zero decks.
No thinking required.
I know you've reached an ''Oh FFS !'' stage, which isn't nice, but the more good news is that you now know what you need.
By the way, you could always have a cam custom ground for you if you wanted.
For info, the DCR of 8.93 remains the same at 0.00 ft and 2,200 ft, but the cylinder pressure drops from +/- 189 to 177.
The cylinder pressure is what contributes to detonation.
All the numbers provided in a calculator are nothing but estimates, but incredibly useful all the same.
What's the part number of the cam you bought for this engine ?
Yes your pistons are suited to OC heads. You need D top pistons for your ''Quench heads'' (CC heads). Yeah, you know that now as well. LOL
I will confess, I dropped the pistons off at the machine shop and didn't inspect them, (crazy busy) My shop is great and I did not catch this until i picked up the short block. They thought i knew what i had and I thought the TM pistons were the ones to have. Foolish me,, anyhow, I caught it, easily corrected. I guess i got caught up in the moment trying to get this back together.
It is unreal how this flu season has derailed everything. I had a hard time getting the heads because the valves came from argentina,, "who knew".
I will pump the brakes a little and just wait it out. Looks like this will not got back together anything soon so may as well take the rest of the truck off the frame and detail it while I am waiting. Sadly, we use this truck everyday and now I am towing a trailer to make up for it.
I found this little 66 for my 8yo daughter, we were going to start tearing it down but at only 8, I think she can wait a few more months
Ok, I see now how the mistake was made. Sh$t !!
You've just made an excellent decision to wait.
Lovely truck and car.
It's a real shame that YOU will have to drive the Stang for a number of years though. LOL
Not to worry about not driving the 66. I got this 67 to keep me in trouble.
406, callies, diamond pistons@11.3 with a comp 294s and AFR 195s and an AED 950. It is a super T10 with 411s. A real handful with BFGs.
Ok, you have a daughter, and she's getting the Stang.
Do you have a son, coz logic tells me that he would be allowed that beauty ?
If yes, then let me go 'n sulk.
If no, great, you can adopt me !
I'll even do the adoption papers and there will be no charge for anything.
Then, ''Dad, can I have the keys please?'.
LOL
back to the ford pistons, Spoke to Randy at Racetech again today, he is waiting for a tech to get back to him. They should have it is the CAD program and I will post the info for a proper 400 piston when using CC heads. TM should change his website for the track boss pistons, Do not care if they have "made power" using their stepped piston before, It is not correct for a CC head. I don't have my old OC iron heads any more, I wish I did so I could clay match/mpld them and see the shape/size of the total combustion area at TDC.
I will document the motor build. The trans will stay a C6 with a stage 2 transgo and a Hughes converter. The 205 case is getting new seals and gaskets.
This is my first ford 400 to build. I read a hot rod article and that seamed like a lot of unnecessary machine work so i went with the TM pistons after searching and not finding much solid info. If I can have custom forged pistons made for 650$ and it works, anyone wanting to build a 400 will have a source for them going forward.
I have read articles about needing or not needing dual quench. Some say it’s helpful to reduce detonation and others say the smaller quench pad isn’t big enough and the main quench area overrides it.
Either way these are Tim’s closed chamber pistons designed for the Aussie heads shown behind the piston. These are 30cc dish with a step to 0 deck and give a 9.4:1 compression with 58cc Aussie heads. Tim no longer makes these pistons. I wonder if the current open chamber pistons could have the tops machined to increase dish?
I would think Tim’s current pistons would work good with the trickflow 72cc chamber heads.
Once you get the motor figured out, it could be a great recipe for others. One thought I had was doing a similar motor with fuel injection and swapping in a 6R80.
