Wrecked 350 revival
Old Jun 1, 2021 | 08:32 PM
wrchd7.3's Avatar
wrchd7.3
Wrecked 350 revival
Hey all recently gained possession of a wrecked 2003 f350 lariat extended cab 7.3 power stroke traded
Cranks just no diesel fuel feeding in.
for a clapped out 1500 Chevy. Looks like I am going to be putting a new cab on and going through the motor slowly but the first order of business is finding a cab and a new wiring harness. This is my second 7.3 and I’ve been on this forum for years finding answers but I’m at a loss for what will fit and be needed for this revival to be done correctly. I appreciate all advice in advance.
Old Jun 1, 2021 | 08:35 PM
z31freakify's Avatar
z31freakify
What's wrong with the cab?
Old Jun 1, 2021 | 08:50 PM
udsuth78's Avatar
udsuth78
Not sure what all you have in mind for the finished product, but a lot of times a complete donor is easier to find than just a cab. Plus that could save you loads on the small nickle and dime stuff that tends to be an after thought. Also don't rule out the possibility that this trucks becomes the "donor".
Old Jun 1, 2021 | 09:02 PM
Listor's Avatar
Listor
regardless stop firing it up with either! you will kill anything that is left!
Old Jun 1, 2021 | 09:35 PM
wrchd7.3's Avatar
wrchd7.3
I have found a complete cab with the engine harness and complete dash but it’s from a 2001 truck not sure if that harness is completely compatible?? 1400 doesn’t sound bad for a southern cab and applicable parts. And of course only gave it a hit of crack to try to start before we winched it on appreciate the concern. My plans for the truck is to make it road legal for use as a welding truck and haul hay. What would cause no power coming to the fuel pump besides the inertia switch?
Old Jun 1, 2021 | 09:37 PM
wrchd7.3's Avatar
wrchd7.3
I will upload more pictures tomorrow but the entire passenger side A pillar is crushed.
Old Jun 2, 2021 | 06:50 AM
Listor's Avatar
Listor
Could be fuses, or a relay sounds like it got hit pretty hard , could have jarred something loose
Old Jun 2, 2021 | 07:02 AM
FordTruckNoob's Avatar
FordTruckNoob
Listor is right. Only two other things directly in the fuel pump circuit besides the inertia switch that can cut power. Have you checked the fuel pump relay is getting power from the PCM Power Relay and ground signal from the PCM?
Old Jun 2, 2021 | 10:32 AM
Brother Les's Avatar
Brother Les
My first Red Flag..... "it runs on Ether"...... Stop doing that right now....
The '01 should match up fine with the '03
Old Jun 2, 2021 | 11:30 AM
Capt'n Jack's Avatar
Capt'n Jack
I once had an old 6.2 diesel that I picked up for free. The guy said 'it runs on ether' I took out the glow plugs, all of them had the tips blown off. I showed him how easy it was to add a little fuel to the intake to see if it would run. Ran great. The same could be done with these, just need to know where to add fuel so you don't blow something up. You can't run it that way, but you can make sure it will run. The only thing ether is good for is seating the beads on stiff difficult tires. It should never be used on any type of engine.
jramsay911
41
Apr 14, 2023 12:45 PM
s.b3nn
May 9, 2021 01:25 PM
riverrat41
Texas Chapter
Oct 29, 2020 07:01 AM
0 Xero 0
Jun 3, 2017 12:41 PM
Robb Kiker
General Diesel Discussion
Oct 2, 2014 02:32 PM
