Weak a/c. 2015 f250
Old Jun 1, 2021 | 11:27 AM
Mattburger89's Avatar
Mattburger89
Weak a/c. 2015 f250
I just bought a 2015 f250 and the a/c blows weak out of the vents. Cooler other day so ran heat and it blows like it should. Just seems week on the a/c side. Recirculate works fan speed you can hear change just never blows as hard as the heat does. Thanks for any input
Old Jun 2, 2021 | 04:58 AM
JWA's Avatar
JWA
What does "a/c blows weak out the vents" mean? Leaving air temperature not to your expectations or is it the air volume that's lacking?
Old Jun 2, 2021 | 08:25 AM
Mattburger89
the air volume is lacking.
Old Jun 3, 2021 | 05:33 AM
JWA's Avatar
JWA
Is this in just the A/C mode or does it follow in the "vent" mode? Does the blower motor work in all speeds as selected by the fan control on the dash?
Old Jun 3, 2021 | 10:43 AM
Mattburger89
Just in a/c mode. Heat mode the volume is good. You can tell the speed changes between all positions just isnt as strong as heat mode
Old Jun 4, 2021 | 05:21 AM
JWA's Avatar
JWA
Just in a/c mode. Heat mode the volume is good. You can tell the speed changes between all positions just isn't as strong as heat mode
Okay that helps since it does seem to be isolated to just the A/C function.
I'm not familiar with the F-Series as far as how the blower air flow direction is changed via the controls such as Heat, A/C, Vent, Heat, Mix ect. If that system is similar to the E-Series I'd check the devices that move any vanes or doors changing the air flow. On the E-Series at the top center of the dash board there is an inspection cover making this fairly easy to observe.
Sorry I can't be more helpful---hope this is easily resolved
Charlieranger30
Nov 7, 2014 06:38 AM
bulldogcountry1
Oct 22, 2009 11:23 AM
Demented5oh
28
Jan 5, 2005 03:57 PM
moejoerizn
Oct 7, 2004 06:51 PM
