Remanned engine, power loss
Old May 30, 2021 | 07:18 AM
Flatbed 97's Avatar
Flatbed 97
I had a remanned 5.8L put in my 97 f350. It seems like it does not have the acceleration or towing power it should. What would cause this?
Old May 30, 2021 | 09:11 AM
Conanski's Avatar
Conanski
What are you comparing it to? These trucks are badly underpowered compared to a modern truck... if that is what you are using as a reference.
Otherwise check the timing and fuel pressure, if those two aren't right the truck won't get out of it's own way.
Old May 31, 2021 | 02:44 PM
diggerrigger's Avatar
diggerrigger
I'd start with the basics too. Look for something that did not get reinstalled correctly. Adjusted correctly.
Old Jun 3, 2021 | 05:53 AM
DaveMcLain's Avatar
DaveMcLain
Many times in a rebuild they will use a "stock" replacement cam but if you plot that cam and compare it to a plot of the old cam it is actually not the same. Another area to look at is the replacement piston. Many times replacement pistons are made with a compression height that's shorter by .020 or so to allow the block to be decked. This can give the new engine a lower compression ratio than the stock engine.
ColeFix
Apr 29, 2021 01:58 PM
olyellow
Nov 6, 2018 05:23 PM
blaze23
May 30, 2010 01:37 PM
