X2 confirm the engine compartment accessible frame rail has the same number stamped on it.
Truck series code F14 ='s F150 4x4
Engine code S ='s V8 400 CID 6.6 Liter 2BBL Carburetor 1977-1979
Assembly plant R ='s San Jose, CA
Consecutive unit number Z01152 A production serial number block system is used to identify model years. X80,001 thru Z25,000=1977
W.B wheel base 117"
Color N ='s Coral, Ford color M1730 ('76-'77 Coral (Brook Blue Metallic)
Type GVW F140
Body PA4 (2nd digit is Ford specific) but PA4 ='s Ranger XLT cab w/ styleside pickup box Ranger XLT (exc. Crew Cab)
Trans G='s Automatic
Axle 16J='s Front-73-'79 Ford w/power strg. Rear '75-'79 3.50 3.75M Ford Except E100/350 '75-'77 3.50 3.6M Ford
Max GVW 06050 (lbs)
1977
DSO 72 ='s San Jose
Interesting set up, cab gas tank, but has gas flap bed. SB and wrong mirror brackets.
