Help with Calibrating PSOM
Old May 27, 2021 | 08:38 PM
GinoS's Avatar
GinoS
I had to get a scrap yard replacement and the new PSOM needs to be calibrated. I did the math and know how to set the calibration and what it should be etc... What I can't find is the cable labeled PSCM that needs to be grounded out. I find plenty of posts for the location of this for the F-150 but none for the E-150... any help is greatly appreciated.
Also does anyone know how I can reset my odometer as the new unit has over 100K more than my van actually has.... do I need to swap the EEPROMs? Or is there an easier way to do it?
Old May 27, 2021 | 10:56 PM
GinoS's Avatar
GinoS
Found the wire - It was located on the drivers side against the firewall all the way against the outer wall. The sticker fell off so be advised it may no longer say PSOM on the connecter but it's the only loose wire that should be in that area and it does have a black connecter on the end single plug.
Old May 28, 2021 | 04:53 AM
JWA's Avatar
JWA
Would have been nice to know what year and chassis you're working with.
E350_traveller
May 2, 2015 10:35 AM
JulieM80
Mar 5, 2013 12:53 PM
wvmudder
Feb 19, 2005 08:10 AM
vaxman99
Jul 2, 2003 07:30 AM
