Sponsored by: Real Truck
Help front outer u-joint replacement
Old May 26, 2021 | 08:44 PM
Fearless1172's Avatar
Fearless1172
I'm grasping for straws here I'm replacing the front outer u-joint on a 2013 F550. When I tighten the four bearing hub bolts the shaft binds can't hardly turn it. I remember I had this problem before on an 02 F350 but I can't for the life of me remember what the problem was. I've had the axle shaft in and out a dozen times can't see what is holding it out any help would be awesome thanks
Old May 26, 2021 | 09:42 PM
WWR's Avatar
WWR
Can't turn like can't rotate or can't swing the knuckle? If the latter pull the shaft toward you or snug the stub shaft nut. The u-joint and ball joints need to swing in the same axis, roughly
If you can't rotate, maybe it's getting shoved into the carrier center pin and snugging the stub shaft nut would still help by pulling it outboard.
Let us know what you find
Old May 27, 2021 | 01:26 PM
Fearless1172
Can't rotate the axle shaft before I tighten I can rotate it freely after I tighten I need a bar to rotate it
Old May 27, 2021 | 01:44 PM
MisterCMK's Avatar
MisterCMK
Do you have the axle seated completely in the front differential?
Old May 27, 2021 | 05:38 PM
Fearless1172
I'll check again I believe I did
Old May 27, 2021 | 08:24 PM
Fearless1172
Thanks for all the help i figured it out I finally said screw it and put it back together stuck a bar in the hub and spun it a few times and all is good now must have just needed to get seated Thanks all👍👍
jasonodsky
Nov 20, 2010 12:03 PM
plgebbia
1997 - 2003 F150
Aug 17, 2010 08:54 PM
JD_F250
13
Dec 17, 2009 07:25 PM
viperbluelx
Oct 3, 2007 12:19 PM
FrontRangeF150
Apr 3, 2007 05:20 PM
