7.3 Godzilla Making 1k HP on Stock Internals
#31
It's far easier and more cost effective to build a big inch Windsor if you're looking for some horsepressure to run at the track. Easy to get to 700HP in NA. https://www.youtube.com/watch?v=ZzD1...dykRobertFedyk
#32
I *believe* its not much, like a clutch plate or two. The 7.3 wasn't designed to be an occasional boat hauler, it was engineered to be a bullet proof, long life commercial alternative for companies not wanting, or not allowed to use, diesel. I don't believe Ford skimped on the rest of the power train as it is Ford's new HD gas flagship.
#34
You asking about the engine or the Powerglide ?
There are Powerglides out there behind 3,000 hp monsters - now there isn't much GM or any GM parts still in it at that point
but they do well.
As far as the engine holding up, these 7.3's are built like a brick ****house. I think you're going to see a lot of crazy builds with them. LS's all over the country are pissing themselves right now.
![Smilie](images/smilies/happy0161.gif)
#35
#36
400CFM heads not needed. Factory head with port and polish will net you 790HP. You can try to slice and dice this comparison but no way can a Windsor run with this engine dollar for dollar, HP for HP. A tune with E85 fuel on a stock 7.3 is 600HP and you can cruise around without a care in the world. Even turn on the AC. Out with the old, in with the new. Again show me a 700HP Windsor for under $23K
#37
#38
This just posted at Ford Authority "Ford working on twin turbo Godzilla" Perhaps this the the "Megazilla" mentioned in the above video?
https://fordauthority.com/2021/05/fo...-v8-exclusive/
#39
I can admit that going real fast is never necessarily cheap by any means and the new 7.3 is such a stout engine. Seems like it makes good power and only time will tell how reliably. But all the signs point to this being a pretty badass design.
I for one would love to see more of these modded 7.3s.
#40
700 hp today is a very easy number to hit with alot of engines running stock bottom ends, the problem with this engine is when you go for big power with alot of boost, headgaskets are **** and dont hold boost well due to slits to help with cooling can you say hello older failed eco boost design, why copy a failed design?. Not a huge ford fan anyway tbh but if I had to run a ford on the track Coyote would be my choice easy handles 4k hp dry deck ect ect, a much better built engine imo.
#41
![Ban!](images/smilies2/sign0024.gif)
#42
Received 1,535 Likes
on
#43
#44
#45
The following users liked this post:
