Body adjustment
Old May 26, 2021 | 01:02 AM
jeffgies's Avatar
jeffgies
Body adjustment
Is it possible to adjust the height of the rear of a 51 F1 cab(with respect to frame)? I don’t see any place to insert shims like one might normally do. I only ask because the bottom of the cab on my driver’s side rear corner is closer to the running board than the passenger side....rubber the paint on the running board in actuality. I haven’t had to do any floor repair work in the rear corners, so I don’t think anything’s changed there height wise. Have replaced the rubber in those mounting brackets.
Old May 26, 2021 | 06:16 AM
avf100's Avatar
avf100
Mid Fifty f1 & f100 parts sell adjustable rear cab mounts that you can raise the rear corner of your cab.
Old May 26, 2021 | 08:05 AM
jeffgies's Avatar
jeffgies
Thanks for the tip. Sounds exactly like what I need. Bed looks a little crooked too.
Old May 26, 2021 | 01:24 PM
52 Merc's Avatar
52 Merc
If the cab is tilted and the bed is crooked, you may have bigger issues than a mount problem. You may want to make, or have done, a very thorough frame inspection. You could have a crack, sagging or a twist in the frame that would be better to address correctly, rather than patch with band-aids and shims.
My 2c.
Old May 26, 2021 | 11:39 PM
jeffgies's Avatar
jeffgies
What I meant was that - like the description for the adjustable arm says, if the bed looks crooked, it's possible that in fact the left side of the cab is low. A flange on the bottom of my cab is making contact with the top of the running board on the driver's side but not on the passenger side. The distance the body line and top of the bed front pan doesn't look uniform from left to right; the eye is not happy. It's all adding up now. There's nothing immediately obvious with the frame, but a thorough examination has not been done.
alecmmfg
2009 - 2014 F150
May 15, 2019 11:11 PM
Mike's Fine 50
Dec 11, 2009 03:52 PM
northeaster79
1978 - 1996 Big Bronco
Dec 9, 2009 06:27 AM
Fomoko1
53
Jun 21, 2006 12:56 AM
snowjob
1947 and Older Ford Trucks
Mar 7, 2004 09:43 PM
