OEM Nav module
Old May 25, 2021 | 08:42 PM
h20camper's Avatar
h20camper
Originally Posted by winglesss
A SYNC 3 vehicle that was shipped from the factory w/o a NAV module and has been upgraded afterwards cannot have the maps updated using that system.
That system shows the vehicle to not have NAV. The Ford database will not be updated to permit a reworked vehicle to get map updates.
Correct but CyanLabs is your savior there. Free and super easy to use. Getting ready to upgrade to the NA2020 maps.
Old May 26, 2021 | 06:38 AM
Mlarv's Avatar
Mlarv
I will ask this again. Will you need to drill a hole and install an external antenna or is it already there?
Old May 26, 2021 | 06:51 AM
h20camper's Avatar
h20camper
I didn't have to add anything. Just swapped the APIM. I do have Sirius that includes the roof fin if that would make any difference at all. I think the trucks may have GPS as the radio has a clock sync to GPS function.
Old May 26, 2021 | 07:42 AM
winglesss's Avatar
winglesss
This reply shows the module swap on my 2021 XL to add NAV.
It was a part swap w/o any programming required.
I have been away from cell coverage several times and am glad I had a GPS nav unit installed in my truck. With that said I use CarPlay more then the installed Nav.
If you install the module won't you need the antenna to make it capture the signals?
On my 2021 XL, w/ the SYNC 3, w/o NAV and w/o Sirius, it was just swap the rear APIM module, removing and replacing the radio.
​​​​​​​Everything worked once reassembled.
Old May 26, 2021 | 07:13 PM
GABAR's Avatar
GABAR
Any and all navigation apps and OEM navigation systems will sometimes lead one down a bad road or give bad directions hence the reason one should always have a different back up or two.
Including the OEM navigation and using my iPhone, I have eight different navigation apps at my disposal and a couple of them can be used offline and without a cell signal just like the OEM navigation.
Old May 26, 2021 | 07:48 PM
h20camper's Avatar
h20camper
Originally Posted by GABAR
I have eight different navigation apps at my disposal......
Wow. I only have two.
Old May 27, 2021 | 06:35 PM
GABAR's Avatar
GABAR
I’ve had Apple maps and Google maps act and lock up at the same time…….very frustrating.
One of my favorite navigation apps is Magic Earth.
Take a look at it and download it to your phone.
It’s totally free and I think you’ll like it.
Dale Massey
Aftermarket Products
Jan 31, 2019 10:14 PM
parkj5
2015 - 2020 F150
Oct 4, 2018 05:19 PM
1toncrew
Sep 2, 2013 12:40 AM
04F-250mark
Mar 7, 2012 11:32 AM
haywoodya69
Jan 10, 2010 04:43 PM
