Drivability Issues. Its a slug that doesnt want to shift
The engine has gone from stalling every 3rd or 4th time I try to start from a dead start to stalling each time I stop. If I very lightly and quickly tap,tap, tap tap the gas pedal JUST SO I can get the truck to move out form a stop. Pretty often I do that tap too hard and it has to then be restarted because it will die. It starts RIGHT back up but wont move out unless I tap, the gas pedal rapidly and lightly again but correctly or it will die again.. It also wants to back fire once rolling on more aggressive acceleration. I have a tendency to have had enough with the trouble getting rolling and want to mash it to punish it for running so weak. That's when it responds by backfiring.
Ive put 6 k miles on it and replaced a bunch of tune up related stuff in that time and have never felt it ran well. Its my first FE engine so Im not sure what to expect. Ive had 302's and 351's, 460's in Mustangs LTD's Linc Continental etc that were responsive. This truck lacks for responsiveness/power..There is a list at the end of this post of stuff Ive done in the order Ive done them.
The transmission has ALSO developed a serious delay in shifting. between 2nd and 3rd gear on most of the shifts in the past week. . .It seems to shift ok if I manually shift the lever. thru the gears.
This truck now gets 5mpg. It has never had what I would call any power. My seriously ugly beater Toyota Tundra with 220K abused miles 3.4 V6 has always been able to smoke this Ford. This F250 is currently incapable of breaking the tires loose.. Its really a lethargic dog. Its gorgeous to look at but runs like poop.
Brutus sat for 5 years before I got it 6k miles ago.. I will be doing a transmission service this week after I have a buddy weld in a drain plug bung on the heavy duty steel replacement transmission pan and the upgraded/reusable LUBE LOCKER transmission pan gasket someone on this forum suggested a ways back when I was getting ready to do a service as purely a maintenance thing.. I have a new filter ready to go also. I am going to try to drain the torque converter also. Ill use type F fluid. The fluid in it is not burnt but it isnt clean either. The truck is parked until I do this transmission service stuff.
Because Im having transmission shifting issues I think I want to also replace the transmission modulator. The one in this truck appears to thread in. Its crusty and rusty looking I cant see any color to know what it is. O'Reilly Auto Parts sells them in Pioneer Brand. The choices are: Black, Yellow,Green stripe and NO STRIPE. The Parts guy said the NO STRIPE was adjustable for the shift points. Dont all the colors have some adjustment? I just use this truck mostly as transportation so whatever is the best stripe color is what I need advice on.
I dont haul or tow anything. Ive been using the beater Toyota to do all the ugly moving stuff Ive recently done. I would like to get this truck to not feel so lethargic. It would be great if I could get back to the 9mpg everyone else "enjoys" which sucks but at least its not 5 like I have been receiving. These past 6 weeks.
I read somewhere that the governor could(also) be a reason the shifts are delayed like they are now. How do I know if the governor is functioning correctly?
Replaced/done in the last 6k miles;
In cab gas tank, fuel pump and its filter. Flushed its fuel lines. New hoses
Local Pro rebuilt carb
New vacuum hoses,(except at the transmission modulator its old but works Ill chuck it when the new modulator get done.
New coolant hoses fan belts
Recharge of A/C.
New Coil, coil and instrument gauge cluster wire harness from Tom's Bronco.
New Hei style distributor Cap, rotor, and 8mm ignition wires. P/O did a Pertronix
New spark plugs
New vacuum choke pull off that sits atop the carb
I run Chevron or Shell Premium gasoline.
Coil Wire/gauge harness
The modulator as it is now
engine bay showing distributor cap and wires.
He looks great runs sluggishly backfires dies on accel, holds onto trans shifts.
If so what shape are they in? Now the new ones I hear are not great (condenser mostly) but maybe time to change them out.
You need to set the points by dwell but you first set them with a feeler gauge to get them close then use the dwell meter.
Once the points dwell is set you can check the idle speed & timing.
If you need to adjust the timing you may need to readjust the idle speed.
As for the transmission not shifting right you cant do anything with it till the motor is running right.
If the vacuum on the motor is low because the motor is wore out the trans will not have the vacuum needed to shift right.
Just the way I would go about checking & adjusting.
Dave ----
If you need to adjust the timing you may need to readjust the idle speed. This truck came to me with a Pertronix the P/O had installed about 25 years ago. The idle sits a bit high at 720 rpm The timing is at 6degrees btdc. The vacuum gauge says 14 at idle.
As for the transmission not shifting right you cant do anything with it till the motor is running right. I found the transmission fluid low by a quart and a half of another quart. I filled it
If the vacuum on the motor is low because the motor is wore out the trans will not have the vacuum needed to shift right. This engine has 71,000 miles on it now I dont think its close to being worn out. The original owner and I are the only owners this truck has had. Mr Miller drove it once a year as a hunting rig to Utah from San Diego. so he put on 2400 miles doing that each year Then he drove it 2x per month to and from work to keep it active. The past 10 years the truck sat with him only starting it here and there. He was ill a lot during this time. I bought the truck from his daughter when Mr Miller passed away.
Dave ----
ADDITIONALLY Im still not sure about the transmission or anything else for that matter. After I messed with everything today, just before dusk I tried to fire the truck up and it wouldnt fire. There was the idea that it wanted to start AS I LET OFF OF THE KEY for just a split second but it wouldnt fire at all while in cranking mode.
Earlier in the day I manipulated the plate the Pertronix sits on to see it wasnt locked up.. Is that something I shouldnt have done? Did I ruin the Pertronix by doing that? I found the vacuum advance not holding any vacuum and I also could blow straight into it so I though I should see if the plate the pertronix sits on would move. Clearly something broke. Before I removed the distributor cap to look inside to see the truck started easily.
It was too late to do anything to see anything more. But it had no spark coming from the coil wire.. I got a group of my neighbors and we pushed it to a parking spot for the night.
The vacuum advance is junk.I can blow right through it and of course it holds zero vacuum..
I probably broke the pertronix. to see if the plate would move, I moved it. and it moves about a 1/4 inch.
I put everything back in place. When I went to start the truck it wouldnt fire up. When letting off of the key during cranking, it gave me the hint that it was firing for a split second. I pulled the coil ignition wire from the cap and looked for a spark....it had none.
Before daylight left I grabbed 4 neighbors and we pushed the truck to a parking spot for the night. Its my guess I wasnt supposed to move the pertronix and probably broke something.relating to it Everything else looks like it did when I started looking at the engine earlier today
One more fact. I used a timing light that has a tack. I left the light connected the whole day. Did the 13.5 volts it was showing on the led screen feed through the coil and fry the Pertronix you know like leaving the key in the on position and not running the engine?
Last edited by mytoolman; May 27, 2021 at 09:29 AM. Reason: wondering if timing light left hooked up fried Pertronix
Just something to think about if you fix everything else and still are having low vacuum.
This is a long time common problem that affects the Auto-Lite/Motorcraft 2100 series 2V carb. Both these parts come in the carburetor kit that's available from Ford and auto parts stores.
D4AZ-9A586-A (replaced C2AZ-9A586-B) .. Auto-Lite/Motorcraft 2100 series 2V Carburetor Kit (Motorcraft CT-499-D)
V8: 1962/74 Ford/Merc Passenger Cars and F100/350 / 1966/74 Bronco / 1969/74 E100/300.
C4AZ-7A377-B .. Vacuum Throttle (Modulator) Valve Diaphragm - Threaded type - White Stripe (Motorcraft TM-2) / Obsolete
1964/72 C4 & 1966/72 C6 // This is the ONLY modulator valve listed for 1968/72 F100/350 360/390 C6 that threads in.
KLIMESH MOTOR SALES in Calmar IA has 5 = 563-562-3241.
GREEN SALES CO. in Cincinnati OH has 8 = 800-543-4959.
When the valve is removed, you have to be careful because it has a shift rod inside that can fall out.
C4AZ-7A380-A .. Throttle Control Valve Rod / 1.677" long / 1/8" diameter / Obsolete
KLIMESH MOTOR SALES has 5.
GREEN SALES CO. has 8.
I installed a new set of points and condenser. Dwell is 27. Timing is 10. Rpm is 700. Vacuum is 19.I adjusted the carb watching the vacuum gauge I added a quart and a half of Type F to put it full on the dip stick and test drove the truck. It really runs great. It has really nice get up and go. Im deciding on if Im going to put an electronic ignition back in.
I still have to do something with the bad vacuum advance. Prices for an entire rebuilt distributor are a third more than just purchasing a vacuum advance so Im leaning on buying a rebuilt The truck moves away from a standing stop easily now.Its very responsive. I have never felt it run like it obviously can until yesterday.
