4R100 gone kaput
Old May 24, 2021 | 04:56 PM
blueoffal's Avatar
blueoffal
Unhappy 4R100 gone kaput
Unhappy Transmission blown or?Was going on an on ramp to a highway, my truck started vibrating and sputtering like it was running out of fuel and wouldn't go past 55mph. Suddenly BLAM! A cloud of black smoke. Pulled over, had full rev range in park and neutral and went back on the road, shifted normally from first, getting to second went a bit over 2500 before shifting then in third it would stay at 60 and go all the way to 3000rpm+ before starting to bog down again. I have no engine light or anything. Did I lose my overdrive or is this engine based? What kind of parameters should I look for using FORScan?
Old May 24, 2021 | 05:46 PM
BWST's Avatar
BWST
Got Data?
Tell us about your truck, year/model, miles, any mods, last things you repaired or replaced.
Always helpful to load up all the PIDs in the how-to thread below and log some idle time, a normal drive, and a WOT run, or a run to recreate the issue and capture it.
https://www.ford-trucks.com/forums/1...d-q-and-a.html
How is the transmission fluid level? When was the last time it was serviced?
An audible "Blam" and black smoke during hard acceleration would point to a blown CAC boot. I would expect it to keep smoking when you pulled back on the road though.
blueoffal
1997 - 2003 F150
May 24, 2021 04:55 PM
chris prater
Sep 10, 2017 06:18 PM
pcarring
20
Jun 2, 2014 12:32 PM
wmiller
Dec 9, 2008 11:16 PM
Jspafford
Mar 19, 2007 04:53 PM
