Air Pressure
Old May 24, 2021 | 02:11 PM
paparoach48's Avatar
paparoach48
4wd Low
Air Pressure
I"m interested in knowing what air pressure you run while towing. I tow 40' 5th wheel .
Old May 24, 2021 | 02:17 PM
KU4OJ's Avatar
KU4OJ
While waiting on the F-250 in the sig, I pull a 30ft 8000# 5th wheel with a 5.4L F-150. I run load range E tires at 70 pounds on all axles truck and trailer. I tried 80 but the truck beat me to death and the trailer bounce at every bump.
When not towing i bring the tires down to 60 pounds.
Old May 24, 2021 | 02:18 PM
Rodknee's Avatar
Rodknee
oh boy.... here we go again!
Old May 24, 2021 | 02:21 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Set it to the pressures listed on the door jamb sticker, that gets you the rated capacity.
Old May 24, 2021 | 02:40 PM
KU4OJ's Avatar
KU4OJ
Yeah well, he asked.
Old May 24, 2021 | 03:04 PM
Rodknee's Avatar
Rodknee
he did. he definitely did ask. i think i responded to the same tire pressure question thread 2x in the last few weeks...
i hate being the old codger that says "search:, but regarding tire pressure, it clearly has been covered numerous times, and everyone has varying opinions.
and yes, if you are towing, go by the door jamb pressures. easy peasy...
Old May 24, 2021 | 07:08 PM
xr7gt390's Avatar
xr7gt390
80 in the front 65 in the rears.
Old May 25, 2021 | 09:04 AM
WE3ZS's Avatar
WE3ZS
Door jamb sticker pressures for full GAWRs or consult the inflation tables for your tire manufacturer and adjust to your loaded axle weights from the truck scales.
Old May 25, 2021 | 10:15 AM
JESTERxHEAD's Avatar
JESTERxHEAD
90 in the front 70 in the rear.
Old May 25, 2021 | 03:48 PM
fleming23's Avatar
fleming23
I put 100 psi in my air bags.
Old May 25, 2021 | 05:41 PM
Kellem's Avatar
Kellem
Tire pressure threads are useless without proper information like tire size, truck, towing or running empty.
Even towing has it's descrepecy, whether it's a 5ver or bumper pull.
Door Jam may well be a good starting point but are we towing or running the wife to the mall ?
Old May 26, 2021 | 09:53 AM
speakerfritz's Avatar
speakerfritz
I was typically running 80 PSI all around. then I went to 90 PSI all around and the only difference is that my 2" heavy duty paver bricks start to corner chip. so going back to 80 PSI all around.
Old May 26, 2021 | 11:01 AM
Rodknee's Avatar
Rodknee
did you contact the dealer? sounds like a warranty issue...
bigtexan99
20
Jun 26, 2010 11:04 PM
sbaset
6.4L Power Stroke Diesel
Jul 12, 2009 02:52 PM
tndiesel
Nov 9, 2007 02:49 PM
Matt M, PA
Jul 10, 2005 09:11 PM
rlh68050
Apr 17, 2004 06:39 PM
