Cab removal
Old May 24, 2021 | 11:24 AM
TURDO's Avatar
TURDO
Cab removal
Hey guys I have a question about removing a crew cab on a 96 f350. Main reason I want to remove the cab is to sandblast and prime and paint the frame, unless there is a way to do this without pulling the cab. I figure if I do pull the cab, might as well do all the body mounts as well. I know the bed is fairly simple to remove, but is it all that terrible to pull the cab off as well? If I proceed to pull the cab I am going to have to find a way to lift it off the frame. Please let me know if anyone has any experience pulling a crew cab and how hard it is.
Thank You,
Christian
Old Jun 4, 2021 | 07:14 AM
ajjw0828's Avatar
ajjw0828
Just recently did this myself. It's a job for sure, and the cab is pretty heavy. I tore it all apart down to just a rolling chassis so that it made it easier to sandblast and paint all the nooks and crannies. The bed is pretty easy, harness, 3 screws on fuel necks, bed bolts, and a couple little support rods for stiffening the side panels. The cab entails removing the 4 cab mount bolts, steering linkage bolt, a/c lines, pcm/ wiring harness (these have a plug on the firewall), and a few other little things but not too much. I put straps through the doors of my cab and lifted above that with a hoist and worked well not damaging the cab. Anyways good luck and be safe with the dry sandblasting, some people believe it causes Silicosis if sand is used.
ClassicKidNick
Jun 7, 2021 11:31 PM
Tmarkh
Aug 17, 2017 08:25 PM
zhigaag
Mar 6, 2006 04:26 PM
