1968 F100
Old May 24, 2021 | 04:33 AM
toddwiebe's Avatar
toddwiebe
1968 F100
I have recently purchased a 1968 F100 and a 1968 C10 Avion slide on camper. I would welcome any input in to suggesting what suspension upgrades would be required to cope with the extra load. Regards Tod
Old May 24, 2021 | 11:22 AM
RV_Tech's Avatar
RV_Tech
Do you know the GVWR of the truck or what the camper weighs?
Steve
Old May 24, 2021 | 01:49 PM
'65Ford's Avatar
'65Ford
As long as you're within reason of your truck's rated weight, I would start with new springs, new shocks, and good tires all the way around and see how you like it. Also, make sure all your steering and suspension is good to go...e.g. rag joint, steering gear, tie rods, new radius arm bushings and i-beam bushings along with new king pins. Beyond those items, I don't expect you'll want any add on items. You can try a stabilizer bar in front and back but not until you've tried it without first.
Old May 24, 2021 | 02:25 PM
85e150's Avatar
85e150
I can't find a direct source of info, but a C-10 is a 10 foot camper, right? The C-11, the follow-on model, is 11 foot. The C-11s weigh 2200 to 2700 lbs according to posts from a couple users here:
https://www.airforums.com/forums/f41...ion-73739.html
So the C-10 will be what, 1800-2000lbs?
I think you are way over for a '68 F100.
Old May 24, 2021 | 05:14 PM
toddwiebe's Avatar
toddwiebe
F100 Avion C10
Steve
Hey Steve, I believe the C10 is about 1500 pounds. I have read elsewhere that the installation of heavier springs and or airbags and gas shocks will get the job done. Also converting the front end to disc brakes and installing a heavy sway bar would not hurt
. Thanks Todd
Old May 24, 2021 | 08:01 PM
HGaither's Avatar
HGaither
I have seen pictures of campers that look way heavy on older ads and they were probably on F100's. Of course they were pictures.
Old May 26, 2021 | 02:44 PM
'65Ford's Avatar
'65Ford
Probably want to drag the camper across some scales to know for sure.
Old May 29, 2021 | 03:54 PM
crewzer's Avatar
crewzer
Here’s a link to the 1968 Ford pickup sales brochure. Check the last two pages…
HTH,
Jim / crewzer
https://www.xr793.com/wp-content/upl...ord-Pickup.pdf
Old May 29, 2021 | 05:23 PM
Wing Nut Bert's Avatar
Wing Nut Bert
HTH,
Jim / crewzer
So a 3-person tent, a coleman stove, two lawn chairs and a pack of hot dogs......no buns.....
Old Jun 2, 2021 | 09:48 AM
17 Oaks's Avatar
17 Oaks
3 things at the top of the list in no order:HD shocks. pick any good quality shock that will fit, Rancho is my go to, but they many have one for your truck, try another MFG
Swaybar either add if not present or consider a larger diameter IF you are driving and experience a lot os lean and sway on corners:
PROGRESSIVE RATE LOAD LEVELING HELPER SPRINGS. if you have any sagging then this and it fits YOUR F 100: https://www.hellwigproducts.com/prod...rd&Model=F-100
IB Cristina
Newsletter Archive
Nov 29, 2016 07:42 PM
masterqi
Feb 23, 2009 03:21 PM
