i finally got to where i can put all my glass back in,so i put windows in but now when i roll window all the way down the regulator comes off the lift with the window still up 2 to 3 in , my question is could i have installed the regulator wrong if so how do you adjust it
If its both windows, you may have them reversed left and right. I had a similar problem with the drivers side after I changed out the piece of metal at the bottom of the window. There is a difference in the pieces.
Thanks ND. One of my window rollers broke over the weekend. I searched the forum and when I saw your name I knew the part number I needed would be there. You are the man!
