window regulator problems
Old May 23, 2021 | 05:27 PM
juchertf100's Avatar
juchertf100
i finally got to where i can put all my glass back in,so i put windows in but now when i roll window all the way down the regulator comes off the lift with the window still up 2 to 3 in , my question is could i have installed the regulator wrong if so how do you adjust it
Old May 23, 2021 | 07:15 PM
spurredon's Avatar
spurredon
Sounds like the glass may be binding in the runs. Hard to tell from here.
Old May 23, 2021 | 07:50 PM
jacobn936's Avatar
jacobn936
If its both windows, you may have them reversed left and right. I had a similar problem with the drivers side after I changed out the piece of metal at the bottom of the window. There is a difference in the pieces.
Old May 24, 2021 | 04:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Nylon window roller attaches to stud on regulator, then fits into the window channel that the glass is adhered to.
The roller is retained in place by a hairpin type clip that is furnished with the roller that's reproduced.
The roller may have broken or the retaining clip could have broken or is missing.
C0AB-6423240-B .. Nylon Window Roller / Reproduced
1961/66 F100/1100 // 1960/64 Galaxie // 1960/65 Falcon/Comet // 1961/66 Thunderbird // 1962/65 Fairlane // 1965/66 Mustang // 1966/77 Bronco.
Old Jun 14, 2021 | 02:52 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Thanks ND. One of my window rollers broke over the weekend. I searched the forum and when I saw your name I knew the part number I needed would be there. You are the man!
Irtnog
Oct 14, 2022 10:42 PM
vwilcox27
Nov 20, 2018 10:33 AM
77mud
1997 - 2003 F150
Mar 8, 2017 05:09 PM
SpankF100
Jan 6, 2005 10:12 PM
caseyatthebat1
Feb 11, 2002 05:01 PM
