2003 f250 steering stabilizer
Most likely there is something causing the vibration. The damper would only be able to squelch a certain amount of that so that you wouldn't feel it. Most likely there is an issue with your alignment or balance of your wheel/tires depending on the vibration (maybe brakes too). The damper would only hide it, if at all.
03, 2003, 73, damper, diesel, f250, ford, issues, kit, powerstroke, stabilizer, stablelizers, steering, truck, vibration
