Rear engine seal leaking
Old May 23, 2021 | 12:53 PM
Bronc1's Avatar
Bronc1
2014, 5.0L, 198K
Rear engine seal is seeping oil about two or three drops over night. Everything else on the truck works fine including the transmission, so, any suggestions?
Old May 23, 2021 | 03:38 PM
gDMJoe's Avatar
gDMJoe
Lightbulb
Bronc1 - 2014, 5.0L, 198K - Rear engine seal is seeping oil about two or three drops over night. Everything else on the truck works fine including the transmission, so, any suggestions?
What does two or three drops over night equate to as far a the oil level being down between oil changes and/or (say) 2-3,000 miles?
If it's less than a quart, recommend some cardboard under the front-end of the vehicle where you park it over night. *That and oil-dry.
Old Jun 1, 2021 | 11:47 AM
Tom's Avatar
Tom
It’s worth mentioning that often a leaky valve cover or head gasket can cause oil to drip down below the bellhousing. I’d make sure you take a peak up the back of the engine before pulling the transmission to replace a seal.
UncleShank
Apr 26, 2011 04:10 PM
b4hntn
1978 - 1996 Big Bronco
Feb 26, 2011 10:20 AM
rutang
21
Jan 17, 2007 08:33 PM
tom9141
13
Dec 29, 2006 10:50 AM
