Interior floor
Old May 22, 2021 | 03:59 PM
Toork's Avatar
Toork
Interior floor
I don’t get a lot of responses in my build forum, so I’ll ask this here.
I have been interested in bedlining the interior of my crew cab. After further research, I’m learning that is not exactly a safe option. Chemical off gassing etc. if it were a jeep that’s run primarily topless that would be one thing, but my kids ride in my truck.
I could get a new carpet or vinyl floor, but they are expensive. In my reading, Lizard Skin is safe for interior use, but it is expensive and spray gun applied only. I was going to roll on a bedliner. I haven’t found another option yet.
Does anyone have an alternative?
Old May 22, 2021 | 04:23 PM
56panelford's Avatar
56panelford
For the project I'm doing now I plan on using this
https://www.dynamat.com/products/dynadeck/
Old May 22, 2021 | 04:58 PM
Toork's Avatar
Toork
Interesting, but that stuff is expensive. 😅
Old May 22, 2021 | 05:57 PM
56panelford
I thought it was fairly reasonable and better than carpet.
Old May 22, 2021 | 08:08 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Durabak has interior roll on-->Durabak Bed Liner | Durabak
Old May 23, 2021 | 05:45 AM
Toork's Avatar
Toork
Prices I saw, it would be $600 to do my crew cab.
Old May 23, 2021 | 05:47 AM
Toork's Avatar
Toork
that might be an option. Website is lacking on detail. I’ll call them for info on the interior lining.
Old May 23, 2021 | 09:05 AM
56panelford
Depends on what you want, you said you were concerned with off gassing because of your kids..
Old May 23, 2021 | 03:33 PM
Toork's Avatar
Toork
It looks like a great option, just out of my budget.
Old May 23, 2021 | 04:23 PM
56panelford
The off gassing will eventually stop with the bed liner, if you have a place to park it where you can keep the window open might help..
Old May 23, 2021 | 09:18 PM
Toork's Avatar
Toork
Ive read some instances where every time it was hit, the bedliner would smell. IDK
Old May 23, 2021 | 09:21 PM
56panelford
I can't say for sure, all I've sprayed is outside the vehicles and you can get high on the fumes.. Might be a good idea to call the tech line of some of the bed liner companies to see what they say..
Old May 24, 2021 | 09:32 AM
BlackBeautyFlareside's Avatar
I'm not sure where you're located at Toork, but around here crewcabs show up pretty regularly at the scrap yard. I've bought all sorts of interior parts there. I'm not certain but I would think you could even get away with grabbing carpet or vinyl from two single cabs and splicing them under the front captain chairs of your crew cab. Just a thought
OR I bet you could put in a generic vinyl floor that wasn't molded for pretty cheap. Maybe put down double sided tape where the contours are to help make it form to the floor.
Old May 28, 2021 | 05:32 AM
humphrey169's Avatar
humphrey169
Look into monstaliner. It might be an option.
Old May 28, 2021 | 09:05 AM
89300T184X4's Avatar
89300T184X4
I used this molded vinyl when I redid the floor of my std cab bricknose. Came out really nice all in all.
https://www.stockinteriors.com/Items...ilterYear=1989
You might find the size you're looking for on that website. ~$150 for me, plus cost of a jute roll. Labor wasn't too bad either, went through a few boxes of razor blades tho.
cypressjeff
Dec 10, 2019 11:25 AM
Dennis Peacock
Nov 27, 2014 11:55 AM
Boba Fett
13
Sep 2, 2013 03:22 PM
mikedeason
Mar 8, 2006 03:53 PM
ryaneverk2
Sep 26, 2005 02:11 AM
